Nails for T Series Body Tub
MGTF1250Dave
Aloha All,
I'm gathering fastners for the rebuild on my TF body tub. Does anyone have a source for the nails used to attach the metal skin to the ash frame? The size is 15 gauge nails with a common head and 1" long. Thanks.
PAUL161
Dave, Go here and ask your question, <span style="text-decoration: underline">you will get an answer! </span>Join the site, it's free, you'll be glad you did. Best T series on the net, with a gathering of the most T series owners anywhere. PJ
https://www2.mgcars.org.uk/cgi-bin/gen5?r...t&subject=8 site on the Net!
MGTF1250Dave
MGTF1250Dave
Aloha Paul,
Thanks I'll ask there. I am a member there also and have read gotten alot of good information from it.
EricG
Please let us know what you find out. A friend is putting together a Morgan body and has been told to use stainless steel nails?? Thank-you. Eric
MikeP
Abingdon Spares used to sell them by the pound, may still do. The ones I got were basically nothing more than a flat head type tack about 5/8" long. I'd say you should be able to get something like that locally, and I would use stainless for moisture protection.
MGTF1250Dave
MGTF1250Dave
Aloha,
I followed Paul's suggestion and posted the question at MGCARS.org and received several good suggestions. I discovered I had been looking in the wrong section of hardware stores. These short nails or brads are generally sold in small packages of about 2 oz. At my local Ace Hardware store I found a 1.5 oz. pack of 15 x 3/4" nickel plated steel nails. This is about 100 nails for about $2.50. I think the nickel plating should offer some corrosion protection.
Most of the nails I have removed from the body tub are rusted but are still intact. Considering they are over fifty years old and had little or no corrosion protection the steel nails lasted well. The car was my daily driver from '76 until about 2004, was not often garaged because I didn't have one so a tonneau cover was usually the weather protection. I think the new nickel plated nails will serve well for the next fifty years.
trrdster2000
Dave, when in England in the 60's getting ready to send my '37 back to the States, I knew I had some rotten wood and talked with a few MG owners to get a idea what needed to be done. Yes, the short one inch nail, but soak them in a soap solution of oxydol (SP), this not only helped the nail slide into a drilled hole but made then rust so they wouldn't pull out. These bodies do move around and one other thing, put a oil soaked gaze in between any wood pieces, before you screw them together. Keeps them from squeaking, you will see some when you take yours apart, and now you know what and why.
Wayne
PS You should buy a handful of small drills, you will break a lot, just go slow and straight in, at a bit of an angle it will break.
bcliff
I have not done any wood framed MG restorations, but I have restored several wood framed Model A Ford bodies. They use a nail that has a twisted shank. I predrilled the nail holes and they work great. I got them from Bert's Model A Ford Store in Denver. On the web at www.modelastore.com. They seem to be fairly hard, not a typical soft wire nail.
Bruce
PAUL161
My TF nails had a slightly domed head, not flat. PJ
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Nunyas NAILS!!! MG 36
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
S M Series Bonnet Striker Pin failures TVR 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
G original radio 1961 e series jaguar Jaguar 3
Y M Series indicator lens TVR 3
Q Series 1 E Type Clutch Jaguar 2
F 1965 Humber Super Snipe Series Va Other British Cars 5
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
David Townsend T-Series MG Midget TC Series Limited Edition Illustrations MG 1
J TR4/4A TR4 Series Vehicle numbers Triumph 1
