TR2/3/3A tr3 body tub color
sp53
Hi All, I am still blasting and scraping away on my 61 tr3 and noticed something. The bottom of the floor pans are painted with a glossy black. I am convinced it is original because of the area and type of paint. It is that flaky shiny black, like on the heater motor. The tub itself is British Racing Green with one coat of red aftermarket. The green kinda peters out as it goes down the firewall then turns into the black. In addition, they used a lot tar towards the bottom for seem sealer. The inner fenders and under the dash are green with a red primer. Under the spare tire was so dirty and rusty, I could not get a color, but I was surprised by the black on the bottom side. I thought under the tub would be body color. I think, I am going to paint the car black, so I guess the purity of the whole mission will not be affected. The guy at the neighborhood body shop supply company suggested. If I use black, I can just buy the paint right off the shelf and will not have trouble matching colors. (Yea right)
Sp53
Tinkerman
Hi:
The Triumph Register of America Judging Standards and Restoration Guidelines states that "The underside of the body tub was sprayed body color and generally not sprayed with masses of undercoater" Page CH-11, section VII, paragraph B.
If you are going to paint the whole body tub and all of the removable panels pick the color you want and go for it. I changed from Signal Red to BRG because the new upholstery kit that came with the car is tan. I thought it would be a better match, personal preference, but historic.
Any how, my thoughts, for what their worth.
Good Luck, Tinkerman
Geo Hahn
My TR3A is Signal Red (as original) but if BRG/TRG had been its original color I surely would have done that and liked it better.
If black is what you like then that is great, but I wouldn't pick a color based on what's on the shelf.
Andrew Mace
sp53 said:
Hi All, I am still blasting and scraping away on my 61 tr3 and noticed something. The bottom of the floor pans are painted with a glossy black. I am convinced it is original because of the area and type of paint. It is that flaky shiny black, like on the heater motor....
Do you mean a "wrinkle" finish? That doesn't sound original to me. Anything on the frame near where the body shows this paint? Only thing I can think of offhand is that -- if this is original -- the car was originally assembled somewhere outside of the UK from a CKD kit. In such cases, bodies were sent out in primer, not in final paint color, and were painted locally.
Just a thought.
YankeeTR
Just a thought.
Ok smarty pants...what's a CKD kit?
Geo Hahn
Completely Knocked Down.
For some reason (taxes?) TR3s were shipped as kits to places outside the UK (Belguim? Malta?).
Andrew Mace
Sorry...I thought the initialism was well-known! Yes, Belgium and Malta are two places where kits were shipped for local assembly, along with Australia, South Africa and other locales. Tax and other legal issues -- sometimes on both ends of the transaction, perhaps -- were a primary reason. And often such cars had some percentage of "local" content, such as upholstery, as well.
Geo Hahn
I've heard that they shipped so many TRs to Malta that one would expect the island to be overrun with low-mileage TRs... alas, I also heard that this was just an interim destination that the use of also had some obscure tax or legal advantage.
S
sp53
I am sorry for the lack of clarity. The black paint is glossy (not wrinkle) black. I will take some pictures of the project and show you what I mean.
Sp53
S TR2/3/3A body tub tr3 Triumph 5
S TR2/3/3A tr3 body tub Triumph 3
K TR2/3/3A The "wide body" TR3? Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
S TR2/3/3A tr3 front apron body work Triumph 9
BlueMax TR2/3/3A No Body Filler On This TR3 Triumph 7
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
J TR2/3/3A TR3 Guy '59 project Basic body work finished Triumph 5
K TR2/3/3A TR3 body fitting question.... Triumph 3
O TR2/3/3A TR3 Body Mounting Hardware Triumph 1
J TR2/3/3A TR3 splash guards... body color or black? Triumph 15
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
J TR2/3/3A TR3 windshield angle and body shims Triumph 11
M TR2/3/3A TR3 to body shop Triumph 8
mgedit TR2/3/3A TR3 Body Mounts Triumph 2
mgedit TR2/3/3A Body back on Frame [56 TR3] Triumph 11
T TR2/3/3A A couple TR3 body questions Triumph 4
T TR2/3/3A TR3 replacement body panels Triumph 14
CJD TR2/3/3A TR3 Body gaps Triumph 20
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
B TR2/3/3A 57 TR3 TS19009 body plates Triumph 4
H TR2/3/3A tr3- body guru's - HELP Triumph 28
G TR2/3/3A TR3 Body Removal Triumph 4
Tr3aguy TR2/3/3A Help....Time for the body to come off [TR3] Triumph 7
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
T TR2/3/3A TR3 fitting body to chassis Triumph 7
M TR2/3/3A TR3 body back on chassis for trial fit Triumph 10
luke44 TR2/3/3A TR3 Body Stripping Bare QuikStrip Allentown Triumph 25
Tr3aguy TR2/3/3A Body removal TR3 Triumph 2
luke44 TR2/3/3A TR3 rotisserie or body buck questions Triumph 24
O TR2/3/3A TR3 Body Panel Fitting Triumph 4
B TR2/3/3A Pulling TR3 body off question Thanks Triumph 15
T TR2/3/3A TR3 crossbar - body color or always black? Triumph 4
mrv8q TR2/3/3A TR3 Body part needed Triumph 4
GBRandy TR2/3/3A TR3 Body tags & Eng S/N Triumph 22
M TR2/3/3A TR3 Body Shell Restoration Progress Triumph 11
M TR2/3/3A TR3 body question seam or no seam Triumph 7
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
M TR2/3/3A TR3 Rear Body Damage Triumph 9
GBRandy TR2/3/3A TR3 Body ID Numbers Triumph 4
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
martx-5 TR2/3/3A TR3 Body Mounting Triumph 1
T TR2/3/3A weight of tr3 body? Triumph 15
Brooklands TR2/3/3A Here is an interesting Devin body for TR3 on eBay Triumph 1
K TR4/4A The TR3 body on the TR4...how did it work out? Triumph 5
H TR2/3/3A TR3 BODY NUMBERS Triumph 37
Russ Austin TR2/3/3A Interesting TR3 Body Mods Triumph 16
S TR2/3/3A Body to frame tr3 Triumph 4
