The tub is on the frame!
tinman58
On Sunday we put the tub on the frame for the first fitting. After cutting two TR3s in halfs to get one good TR3 all the bolt holes lined up. Now we will do all the body work while on the frame. Then lift it off for paint. Then the fun part begins "reassembly". I had the headres ceramic coated and some of the other engine parts powder coated. Added a oil cooler, 12' puller fan, ported head and redid the exhaust. I don't think that I will make it to the TRF in SLO with the TR3 but we will drive the Audi down for the weekend.
P.S. Thats Moe and Jason "THE BODY GUYS"
apbos
Dan
Great progress as always! If it gets tight and you need some bolting help let me know. I now have experience removing TR3a rear fenders :wall:!
Paul
hermanmaire
Nice detailed work .... I like it. I wanted to get some parts powder coated but it just did not happen
tinman58
tinman58
Paul
How many bolts did you break or strip out?
angelfj1
Dan: Looks real nice! I see you haven't tackled the stone guards yet. I would be very interested in hearing about your experience with them when you get to it. Real bear of a job to get nice.
Good luck, Frank
TR4nut
Beautiful work. Does your crew travel to Texas? I need help getting that kind of panel alignment on my 3A!
Randy
emmett1010
Hi Dan;
When I went to reassemble my TR3, I discovered that the rear bumperette holes needed to be raised. To reshimm the rear body mounts, the four main body bolts had to be loosened, and also reshimmed to keep the doors from draging. Then the front needed adjusting.
May I suggest that you check your rear bumperette bolt alignment. It would've saved me a bunch of time.
Emmett
NickMorgan
Looking great Dan. Just a shame that you are having to go through it all again so soon.
tinman58
tinman58
Frank
The first time I did the stone guards was fairly simple. Just trim and fit, trim and fit, trim and fit, etc. Use plenty of blue tape to protect the paint.
angelfj1
tinman58 said:
Frank
gee, some guys have all the luck!!! :yesnod:
S TR2/3/3A Bracing the tub for removal fom frame? Triumph 14
DornTRoriginal TR2/3/3A Tub gap between Frame Drivers side Triumph 3
S engine is back, tub is bare,frame is bare Question Triumph 9
PatGalvin TR2/3/3A Fitting tub on frame - 59 TR3A Triumph 8
PatGalvin TR2/3/3A Tips for fitting tub on TR3 prepared frame Triumph 23
B TR6 I have to buy a used frame and tub for a TR6..... Triumph 14
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
T TR2/3/3A Body Tub Weight Triumph 8
F TR2/3/3A TR3A tub assembly Triumph 44
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
S TR2/3/3A steering column through the body tub Triumph 5
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
S TR2/3/3A tub work and holes Triumph 11
Popeye TR4/4A Best way to transport a bare tub? U-haul utility trailer? Triumph 11
S TR2/3/3A painting the body tub “inside” Triumph 31
S TR2/3/3A body tub welded Triumph 2
B TR4/4A Body tub differences - TR4/4A Triumph 8
C TR2/3/3A Flipping the tub Triumph 9
Hot Wings Title for a tub? Spridgets 9
CJD TR2/3/3A TR2 Tub Triumph 9
B T-Series MG TD Tub MG 5
B T-Series Tub Size MG 2
B Question about my 57 body tub Triumph 2
MGTF1250Dave T-Series TF Body Tub MG 3
MGTF1250Dave Nails for T Series Body Tub MG 8
K TR4/4A Bracing the tub for fender and sill removal TR4? Triumph 6
S Body tub shims Triumph 1
J TR2/3/3A TR3 tub weight? Triumph 16
O TR6 TR 6 Body tub Removal Triumph 9
A Material between front fender and tub Triumph 15
G TR2/3/3A Threaded rod to Assist TR3 Tub Placement Triumph 6
M Tub Almost ready to come off [pics] Triumph 10
S TR2/3/3A tr3 tub shims Triumph 2
Twosheds TR2/3/3A TR3 Tub Hauling Question Triumph 16
PeterK TR2/3/3A Good TR3A tub for $400 Triumph 6
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
B Spotted a Bugeye tub- Spridgets 0
G Rust free tub in MN Spridgets 2
MGTF1250Dave T-Series TF Body Tub Rebuild MG 10
S TR2/3/3A body tub tr3 Triumph 5
John Moore Big Milestone! Tub is stripped Spridgets 6
apbos TR5/TR250 Triumph TR5 tub Triumph 1
S Midget body tub Spridgets 8
tony barnhill '63 Tub Epoxy Primed Spridgets 8
C Will older doors/sliders work with MkIII Tub/Top? Spridgets 23
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
RickB MGC MGC-GT tub in Seattle MG 3
J stupid question of the day - dipping the tub Triumph 4
