Midget body tub
S
sreinh3115
I'm planning on completing a restoration of my '70 Midget that I've owned for 16 years. Rather than cutting out a bunch of rotted panels, I picked up a very solid body ('70 or '71)in '04 that had most of the new panels welded in already. The only exception being the drivers side rear fender half and the door cowl panels on both sides. I proceeded to clean it up and coat it with POR 15.
Now I've got an opportunity to pick up another body tub from the southwest that that has everything all ready to go with the exception of a hole in the drivers side floor. It's from a '65.
I may be losing my mind but I'm seriously considering switching to that tub. Any thoughts, pitfalls, etc. that anybody could offer up, would be appreciated. Thanks!
Jim_Gruber
'66 has the better looking , Non Padded Dash.
GeeBee1
Welcome aboard.
What are your end goals with this project?
1. To restore the car that you have had for 16yrs
2. To have a mark II or III
3. To be fully original (1275 vs 1098)
4. Which subtle body style do you prefer
5. What has the most parts that do not need to be purchased
6. what is your planned budget and timeline
The 65 probably has some rust that you are not noticing, and the 70 with the por 15 will probably rust back.
From what you have described, being a sentimental hag and liking the 1275, I would lean to the MKIII if it was me.
Jim_Gruber
Where are you in Ohio? I did a DS A-Post Repair over winter on Bugsy my '68. Not all that hard to do but not nearly as easy as replacing a floor that you cannot see once carpet goes in. Still need to do PS and RS Rear Fender. This coming winter's project. I personally perfer the earlier non padded dash but a matter of personal choice. Oh yeah another future project, I've got a replacement padded dash to install, got to find a few hobbits or wee folk to get their hands up underneath the dash to loosen up those 5 nuts. I don't even want to think about that project.
Dug
I agree with Jim,
The downside is all the bits that wouldn’t look right from a 70’s in a 65. There are so many things so very different that you would be pulling your hair out trying to figure out what to do? Do I use the 70’s wiring?? With 70’s gauges, switches etc. or?? So many of the other electrical bits are different. They all work the same (98% anyway). Wiper motor, square style as in the 65 or round like the 70’s. Master cylinder is very different, including the hole in the tub. All of the items are doable from one body to another but at what cost?
Does that help?
Dug
S
sreinh3115
Thanks for the responses so far. I’ll try to answer all of the questions at once. First of all, I live southwest of Cleveland in Medina County.
As far as my current tub goes. It does have mostly new panels welded in. And very nicely done for the most part. The problem is the inner A posts. The guy welded them a little too far outside so that when the A post covers are put in place they are significantly out of line with the doors. As a result, I’ll have to do some cutting. In addition, the car has many small dents that I’ll have to deal with.
The ‘65 tub has the rust issue in the floor (that I know about) and not much else. It is also mostly intact and is only going for $250. Part of me says to save my money and keep going on the current project but another part of me thinks that I’d be a fool to pass it up.
Therein lies my dilemma.
tosoutherncars
If your current tub is a "known quantity", I'd stick with that. You've got one minor issue to sort out... but a seemingly OK tub could be hiding any number of equally problematic surprises for you to discover.
My $0.04 (inflation due to rising gas prices)
Jim_Gruber
I'm guessing edge of doors is rubbing on A-Post. Had that same issue when I replaced DS- A-Post when I put the outer skin on. Take an adjustable box wrench, monkey wrench and adjust it down to the size of the outer skin. Work it up and down and you can relocate that entire A Post Skin and probably get it to fit. If all else fails the BFH works well.
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
BJ8Healeys Mk III Midget Body Parts Service List Spridgets 3
K Midget "Heritage" Body Shells? Spridgets 2
RickB Craigslist Midget body - free or cheap Spridgets 1
B Seattle Guys- Free Midget body Spridgets 8
A 76 MIDGET WINDSHIELD SEAL FRAME TO BODY Spridgets 13
J chrome body trim pieces on a 79 midget ? Spridgets 13
RickB 79 [guess] Midget body& parts free in Issaquah WA Spridgets 2
tony barnhill 1963 Midget Body Up-date Spridgets 7
tony barnhill '63 Midget Body Structure Question Spridgets 18
Atrus MKIII midget body teim - how fastened? Spridgets 5
T Midget body shell for sale - Ortega Highway SoCal Spridgets 0
A 76 Midget Body Trim Moulding Spridgets 0
K New Midget body shell? MG 11
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
