76 MIDGET WINDSHIELD SEAL FRAME TO BODY
Alvin
Member
I am replacing the bottom Windshield seal that goes between the windshield frame and the car body (cowling). The old one came off pretty easy, but I need some "guidance" on how to install the new one. My aluminum channel is in very good condition. Do I heat the new one up first? Use some sort of "lube"? Unscrew the bottom windshield frame first and then slide it in? As always, thanks for your help.....AL
JPSmit
Mine just slid in I don't recall needing any lube - the real challenge will be reattaching the window to the car
A
Alvin
Member
When you guys say just slide it in, does this mean with the everything still in place? The post seems to be in my way, and I will have to do a lot of bending and pushing to get the gasket in the slot?
G
MIne came from VB and slid right in. Better to pull than push, but you'll have to do both probably.
G
Just have two screws in mine. I'm letting the rubber compress a bit more before I try the other two. It's a bear for sure.
lbc_newbie
When I did mine, I found a trick on one of the MG sites that suggested running duct tape along the under-side of the front lip. This will give you something to grip while you pull that lip out along the cowl. Have a buddy on the other side tighten the bolts in the center under the mirror first and it will compress and hold it for the end bolts. Then, you get to have fun with shims and bolts.
G
NO, you don't. IIRC, I went in by the screw hole, got it all the way down the other side, figured out how long I needed it, cut it, scrunched it up and fed it in the other side of the screw hole.
Think about it, if you take the side off, how you gonna get to the screws to put the side back on?
Jim_Gruber
I just took off the side pillar, came right apart and I replaced the screws with something that was a real close replacement from local Ace Hardware store. MOSS piece slid right in the track with no issues.
A tip on fitting shims. I cut a slot for both top and bottom bolts so I could get screws started and then I could slide the shims in from behind. Worked really slick to do this job myself.
G
Ya know, maybe I took the side off and then sqished the seal up to get to put thr screws back in. I don't remeber but it went in too easy to go in through the screw holes.
M General MG Midget MK1 windshield replacement MG 2
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
K For Sale MG Midget Windshield Spridgets Classified 0
RickB Where to order windshield seals for 78 Midget? Spridgets 3
M While I've got the Midget's windshield off... Spridgets 10
A 76 MIDGET WINDSHIELD GASKET & WINDSHIELD INSTALL Spridgets 1
lbc_newbie 78 Midget windshield woes.... Spridgets 2
J Windshield washer 1978 midget-bag on fender system Spridgets 0
R MG Midget Windshield help MG 13
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
