Midget front shocks
JPSmit
SaxMan
+1 - All four of my shocks are from Peter. When one of my front ones that I purchased from Peter failed, he replaced it, no questions asked.
Jim_Gruber
X 3 for Peter's Shocks. Sure you can refill but they will still be leaking. His are better than new and do not leak.
AngliaGT Front Brake Dilemma - '74 cb Midget Spridgets 4
O Need front driver's side fender 65 Midget Spridgets 0
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
P holes in 76 midget 1500 front bumper Spridgets 6
P front wheel bearings for 79 midget? Spridgets 4
G 79 midget front side marker lens Spridgets 13
c5racer B Front Air Dam on a Rubber Bumper Midget Spridgets 3
O Front disc's from a 63 Midget Spridgets 0
S Something very different in front of my Midget Spridgets 9
tony barnhill 1963 Midget Front Suspension Spridgets 24
Dadandson 1974 Midget Front Brake calipers Spridgets 4
regularman 71 midget front turn signal lens question Spridgets 2
J 79 midget 1500 front suspension Spridgets 33
B 1969 Midget front hub bearings MG 0
B 1969 Midget front hub bearings Spridgets 7
L MG Midget Front Springs MG 5
MGFever Midget front suspension MG 13
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
