1969 Midget front hub bearings
BlackHealey
Hello MG owners, I am rebuilding the front hubs for a friend's 69 Midget and I am having a heck of a time trying to attach the hub to the axle. I bought new wire wheel hubs, new bearings and rebuilt king pin/axles. I set the bearings in place with a drift and when I slide the hub over the axle, the axle does not protrude above the outer bearing, so I am not able to install the nut and washer.
The hub is all the way on the axle, as it can not go any further without hanging up on the rear plate. Does this mean that the outer bearing is not installed completely? I have to hit it pretty hard with the drift and mallet to get it where it is currently. I am not sure how hard I should have to tap it to get it in place.
Is this a common problem?
Please help!
Thanks. /ubbthreads/images/graemlins/confused.gif
rimzimmer
Member
The bearings do have to in a certin way round (Outer thrust in)otherwise the wheel can fall off, but as the are not tappered the hub shoud still sit in the right place, are the bearings the same size as the old ones?
When hitting the bearings in try to us a large socket or pipe off cut the fits the outter race this way the load is spread evenaly and the baering ahs a better chance of going in square, the note of the sound will change when the bearing has hit the bottom so thats when to stop hitting it!!
You should probably pst this in the spridget forum. But it sounds like the outer bearing is not completely seated. the above advice seems good. BTW, this is not a common problem that I know of.
Ed Kaler
[ QUOTE ]
[/ QUOTE ]
Are they for WWs?? /ubbthreads/images/graemlins/confused.gif
Ed
aeronca65t
Shouldn't be any big deal.
You have everything set up as in the picture below, right?
I love exploded diagrams. /ubbthreads/images/graemlins/grin.gif
PeterC
I have a feeling you followed the diagram! With the hub in your hand looking at the inner, oil seal side, the outer bearing gets pressed or drifted all the way in away from you, then the spacer, then the inner bearing, then the oil seal. I have a suspicion you are trying to put the bearing in from the outside after the wheel is on the spindle, like an MGB. That diagram could get you thinking that way. PM me if you need help. Peter C.
Ya know Peter, I've looked at that diagram many times and never noticed the bearing being on the outside of the hub. Hmmm, probably because I replaced the bearings before looking at it.
B 1969 Midget front hub bearings MG 0
L For Sale 1961-1969 AH Sprite, MG Midget Chrome bumpers & hardware Spridgets Classified 0
J New 1969 Midget owner here. getting rid of parts Spridgets 27
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
AngliaGT 1969 Ford Galaxie Spotted 3
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S For Sale MGC Factory Workshop Manual on CD/ROM - 1967 - 1969 Models MG Classifieds 0
oldbagpipe For Sale Early 1969 TR6 'Stalled Project' $4500 Triumph Classifieds 0
AngliaGT 1969 Impala Convertible Spotted 0
oldbagpipe For Sale Early 1969 TR6 Project for sale Triumph Classifieds 10
M Wanted MGB grill 1963 to 1969 MG Classifieds 2
Got_All_4 TR6 What is a 1969 TR6 seat worth? Triumph 5
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
Raymond MGB 1969 oil filter MG 4
C TR6 Need help with a 1969 triumph tr6 Triumph 21
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
June TR6 1969 tr6 Triumph 17
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
S MGB 1969 MGB No spark to plugs MG 5
jmayzer 1969 sprite - good deal?? Spridgets 17
W What motor will fit my 1969 Austin Healey Mark IV Spridgets 29
W What motor will fit my 1969 Austin Healey Mark IV Austin Healey 5
RickB As seen on Craigslist [Seattle area] 1969 Austin Hensley [SIC] Spridgets 0
J Confusing Seat choices for 1969 Mini British Motor Corp 8
A 1969 Sprite. Month: 8 Spridgets 2
H 1969 Jaguar XKE - Oil Jaguar 7
aeronca65t 1969 Watkins Glen F1 Racing 9
S MGB-GT FS: 1969 MGB GT 64k miles, overdrive, a lot fresh. MG 18
T Difference between 1969-74 and later exhausts Triumph 7
AngliaGT 1969 LeGrand FF - Anyone Have Info? Racing 2
S Spitfire For Sale: 1969 Spit Fire MK3 Triumph 1
K clutch 1969 sprite Austin Healey 4
T TR6 WTB - 1969 TR6 fan Triumph 7
JRC Spitfire SF Chronicle - 1969 Spit Triumph 2
D 1969 Austin Healey Sprite Rebuild Spridgets 16
Z MGB MGB 1969 Trim query MG 6
abarth69 MGB-GT 1969 MGB GT with automatic MG 2
d_valentino 1969 Mini w/ automatic gearbox and air bags British Motor Corp 12
C Uh Oh, I do I really have a 1969? Spridgets 36
