mrv8q
One of the "easy" things I wanted to do on the '74 TR6 was replace the rear gearbox mounts... they were pretty cruddy, and I wanted to change them before installing the new plastic gearbox cover(s). I used TRF mounts, w/ no surprises, although I wished TRF supplied 4 new nuts w/ the new mounts...
All in all, not too horrible a job. The Bentley says to remove the exhaust pipes; there was no way I was going to do that! Here's a pic of the gearbox brace out of the car:
A pretty sad state, lots of accumulated grease.
This is a job one person can do, but with a lot of back and forth under the car. The hardest part was placing and keeping a stubby 9/16 on top of the gearbox brace, and removing the 4 nuts from underneath.
I found it impossible to remove just the rubber mounts; I needed to remove the whole brace. I removed the top "half" first, and then the hard part, the "lower" half.
Surprising to me, the the "bottom" half is actually two pieces bolted together; I imagine easier to initially assemble.... that's how I did it.
The next two shots are of the completed job:
Here's a sad bolt: the one not missing from the bottom half. This side was on the passenger side of the brace, "barely" hanging on to a tab that helps hold the exhaust pipes.
Tomorrow I'll install 4 new Nylocs for the driveshaft u-joint, change the gear oil, and mark off one more small thing done. Next, the carbs, especially the leaky rear one...
I found this a satisfying mechanical job; just figuring out how it was assembled, and then tackling it. What was most helpful was having lots of stubby and regular sized wrenches and Gearwrenches.....
