TR2/3/3A TR3A steering box
newguy
This is such a great forum to visit when you feel like an idiot. Just finished rebuilding the front end (steering). New tie rod ends, silent blocs, steering arm, lever and other associated parts. This took almost all of the free play out of the front end. The remaining seems to be in the steering box. Can someone assist with whatever the perscribed adjustment method might be. Or if there are other things I should be looking at.
Mickey Richaud
There is an adjustment set screw on the top of the box, with a locknut. You should get a shop manual, as it has all the detail about how to adjust, and how much play there should be. Hopefully, you can adjust it enough to make a difference. Otherwise, you may be looking at a rebuild of the box.
This would be a good time to top up the fluid in there, which may be a contributing factor. Details also in the shop manual.
Hope this helps.
Mickey
TR3driver
Great Pumpkin - R.I.P
There are also shims under the front cover of the box, to adjust the end play.
However, neither of the adjustments is really intended to compensate for wear. If the box is worn, the only solution is to rebuild it, and replace the worn parts. Just replacing the peg, bushing (and seal) made a huge difference in my TR3A; one of those "Why didn't I do that sooner?" experiences.
It also convinced me that trying to compensate for wear by pulling up the adjustments is a Bad Idea.
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T TR2/3/3A How to identify what steering box and column I have on a TR3a? Triumph 12
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
Bremer TR2/3/3A Steering box rebuild TR3A Triumph 8
N TR2/3/3A steering box for TR3A Triumph 14
T TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
Got_All_4 TR2/3/3A Removal of Steering Box Worm Gear In Car TR3A Triumph 3
TRclassic3 TR2/3/3A TR3A steering box oil Triumph 10
J TR2/3/3A TR3A Adjustable Steering Triumph 5
K For Sale TR3A Steering wheel Triumph Classifieds 4
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
Brinkerhoff TR2/3/3A TR3A steering column grommet - picture? Triumph 2
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
BJ8Healeys TR2/3/3A TR3A Steering Gearbox Triumph 27
Lukens TR2/3/3A Aligning steering wheel on TR3A Triumph 3
Simmo TR2/3/3A Mota Lita Steering wheel on TR3A. Help! Please. Triumph 4
PatGalvin TR2/3/3A Steering Wheel Diameter with R&P Steering, TR3A Triumph 9
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
60TR3A TR2/3/3A TR3A Conversion to Rack-&-Pinion Steering Triumph 33
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
G TR2/3/3A TR3A steering column Triumph 10
Tinkerman TR2/3/3A TR3A Steering Column Clamp Triumph 7
CraigLandrum TR2/3/3A TR3A Steering Shaft stator tube??? Triumph 26
angelfj1 TR2/3/3A TR3A Steering Worm - Can this be Restored? Triumph 15
M TR2/3/3A TR3A steering wheel splines Triumph 1
rlandrum TR2/3/3A TR3A Steering Bearing and Race Triumph 3
angelfj1 TR2/3/3A TR3A steering column [two-piece] coupling Triumph 2
MGTF1250Dave TR2/3/3A TR3A Steering Wheels and Columns Triumph 13
C TR2/3/3A I want to change my Tr3A steering wheel... Triumph 6
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
N TR2/3/3A TR3A Steering Adjustment Triumph 6
F TR2/3/3A TR3A Steering Wheel Cover Triumph 1
Dan_Pasta TR2/3/3A TR3A steering rebuild help Triumph 10
Dan_Pasta TR2/3/3A TR3A steering slop Triumph 0
S TR2/3/3A TR3A steering wheel Triumph 32
S TR2/3/3A TR3A steering column- one piece column removal? Triumph 4
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
