TR4/4A Toyota calipers for a TR4A
tdskip
This maybe be a bit of a repeat thread, sorry. I tried a quick search and this exact topic didn't come up but I kind of remember already asking this.
Anyway, the TR4A needs a caliper rebuild. Taking standard Moss pricing to do this;
585-522 Classic Gold Premium Ceramic Brake Pads $38.95
582-000 PISTON $14.50
583-000 REPAIR KIT (for 2 calipers) $25.95
182-100 BRAKE SHOE SET, 4 shoes $21.95
You end up with a total of about $145 (LBC and others might be less) plus getting them blasted and painted etc figure you are in the $160 range plus the time (which is at a premium these days).
The price of two new fully loaded Toyota calipers from Rock Auto is $122. Adding in converting piping from TSI for $45 you end up with a cost of about $167.
I'm kind of wondering that, save for originality, why not just go with the Toyota calipers. I did the conversion o the TR6 and they are working great.
HerronScott
Tom,
The brake shoes don't come into this calculation since they are for the rear correct? Also, for cost comparisons, are the brake pads that come with the Toyota calipers the same level since your spec'ing ceramic ones for the rebuild? RockAuto has standard BeckArnley TR4A pads for $17.51 for example.
Scott
T
tdskip
Well I blew that! Thanks for catching my error, a bit early here when I did this. Should look like;
585-527 Classic Gold Semi Metallic Brake Pad Set $27.95
Subtotal $111.90
RJS
Hi Guys,
I am interested in some further details on the Toyota swap. Do you have part numbers for the calipers? Are they a straight bolt on with stock rotors?
I have heard the Toyota calipers are a performance upgrade if you do not care about originality. 4 piston vs. 2 piston and I read somewhere that the brake pads themselves are 45% larger, providing more friction area.
Cheers
martx-5
Here's the whole lowdown on the conversion from the vtr site. The article will tell you everything you need to do the conversion, and has some statistics on their effectiveness.
I put them on my TR3. Of course, I work for a caliper rebuilder, so I got a pair at a very favorable price. :smile:
swift6
Early cars need the later Metric bolt with standard threads of the later TR6s. The shank of the bolt is thicker and needed for the Toyota calipers. The only performance increase would be in reduced fade. There are twice as many pistons, but essentially the same piston surface area. They offer essentially the same clamping force. The Toyota pistons are also heavier, especially if you use a Cressida vented rotor.
The brake mod that will yield the most results for the money is to change the rear wheel cylinder to a larger bore and increase the rear braking capability. There is a wheel cylinder for Morgans Sunbeams and Datsun 510's that bolts right in, same brake line thread connection and externally looks identical to the original wheel cylinders.
martx-5
swift6 said:
... The Toyota pistons are also heavier, especially if you use a Cressida vented rotor.
I didn't use the vented rotor calipers on my TR3, but I can tell you that the Toyota calipers were lighter then my TR3 calipers. The vtr article mentioned weight, but they were unsure...Sorta..."the Toyota caliper is not appreciably heavier than the Girling caliper, and may even be lighter." That's not saying anything definitive, but if they are heavier then the TR4-TR6 calipers, it won't be by much, as they are lighter then the one piece TR3 units.
swift6
Caliper weight itself is nearly a wash, but if you try to use the vented Cressida rotor then the caliper has a spacer and the rotor itself is heavier.
TR4nut
And not to steal this thread (too much!), that's why I'm thinking about the Toyotas as well for the 59 3A - I have the one piece units, they need a rebuild and they weigh an absolute ton.
martx-5
Read that article I linked to earlier. The biggest problem with putting them on a TR3 is the caliper bracket. You will have to source them from someplace, as I don't think they are available new. The Triumph club I belong to had some TR6 front ends laying around, and I snagged the brackets from them.
PeterK
I picked up TR6 brackets on ebay for cheap for when I finally convert the 3A. These brackets are needed for TR3x only.
But all TRs will need the caliper mounting bolts from a late model TR6 - the metric shank fits the Toyota. Also slight trimming of the dust shields or remove them altogether.
TR3driver
Great Pumpkin - R.I.P
You may also need to trim the TR3 rotor a bit. The TR6 mounts move the caliper a little closer to the axle (which is why the TR6 rotors are smaller).
PeterK
Here's what my fronts look like on my 4A.
First I did a dry assembly on the bench
Brosky
Nice job Peter. That is a classy assembly. The red calipers are just a bonus, Tom. But a nice one, indeed. And don't forget the shocks too!
PeterK
The shocks are Konis, naturally red.
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
Westfield_XI Which Toyota Calipers? Spridgets 44
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
Michael Oritt Toyota 5-speed Problem Austin Healey 28
J TR6 Toyota Transmission conversion Triumph 8
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
S '81 Toyota Celica Other Cars 8
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
aeronca65t One less Toyota 2000 GT Other Cars 5
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
glemon TR6 Toyota Caliper Conversion Triumph 28
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
aeronca65t Toyota 2000 GT Spotted 9
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
Patrick67BJ8 Toyota 5-Speed slides out of 5th gear Austin Healey 19
T Question I should know - which rotor for Toyota Triumph 9
Sherlock The ultimate Toyota Land Cruiser? Plus a Jeep too Other Cars 3
T BN1 Toyota Gearbox Austin Healey 4
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
4 Another Toyota Twink Spridgets 13
M Toyota 5 speed Shifter Austin Healey 2
tinman58 Toyota trans noise Triumph 9
PatGalvin TR2/3/3A Toyota Brake Conversion on a TR3A Triumph 5
PatGalvin Routing brake lines for Toyota 4 pot conversion Triumph 5
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
M synthetic fluid in a toyota 5 speed? Triumph 20
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
prb51 Tr Toyota 5 speed upgrade Triumph 24
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
prb51 Toyota tranny users-Speedo Triumph 15
prb51 TR2/3/3A Tr3 club Toyota conversion Triumph 24
