As long as the Toyota calipers you are using call for<span style="font-weight: bold"> non-vented rotors,</span> stock TR or, as mentioned above, any of the performance rotors will work fine.
I have drilled rotors on my TR3 with Toyota calipers. The drilled and/or slotted is more of a bling factor then any advantage you may gain in street driving. So if cost is a factor, stick with stock. What I have noticed with my drilled rotors is that when I step on the brakes, they make a curious, almost whistling noise. :laugh:
