Routing brake lines for Toyota 4 pot conversion
PatGalvin
Any thoughts how I should route this nice SS cable I purchased from Ted of TS Imports? It seems awful long to me but I'm no expert. Either hits rubber on tire or conflicts with bumper on shock pan. Darn, maybe I should have stuck with stock calipers?
Also, does the caliper clip ride on the rotor? I can't believe that is the case but that is how they shipped from Rock Auto.
Pat
martx-5
Those hoses are too long. Looks like they are for the TR4/TR6 where they have to go around to the front side of the suspension. This thread shows the arrangement on my car. I had to make the extra bracket. Also, notice that I left off the springy things...didn't have them...don't miss them. I used cotter pins where the long spring is used to hold the brake pad pins in place. Now that I think about it, are you using an 11" or a 10 3/4" rotor. If it's 11", maybe that's why the spring is hitting the rotor.
The important item is the length of that hose. Call Ted and see what he has to say.
davidk
I believe the end of the clip should be bent upwards more so that it doesn't touch the rotor.
PeterK
My clips are installed the same way but yours looks 2b thicker wire. Just bend it up a bit to just miss the rotor.
PatGalvin
PatGalvin
Thanks for the tips about the clips. I can easily bend those up.
Ted asked me to measure the line and return to him and he'd get it cut to size. I'll either do that or return and use the short hard pipe adapter and home-fabbed bracket, similar to what Art did.
Thank for the tips. I really enjoy this forum and have lots more challenges ahead of me in coming months.
Pat
S Routing of Hand Brake Cable Austin Healey 6
R Help with BJ7 front brake line routing Austin Healey 6
Rut Brake line routing Spridgets 21
AHS TR2/3/3A Disc brake line routing Triumph 0
C Vacuum line routing for brake booster Austin Healey 5
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
T TR2/3/3A TR3 front brake line routing Triumph 3
chicken Brake servo pipe routing Austin Healey 1
CinneaghTR TR4/4A TR4A Fuel and Brake Line Routing and Dual Exhaust Triumph 6
W A-H brake line routing Austin Healey 8
JPeter TR 3 Rear steel brake line routing Triumph 11
C Brake Line Routing Austin Healey 16
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D BT7 Air Vent Control Cable Routing Austin Healey 0
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
Healey Nut Rear Wiring Routing Austin Healey 2
Healey Nut Wiring Harness Routing Austin Healey 5
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R TR2/3/3A Speedometer Routing Triumph 15
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
M TR4/4A Speedometer Cable Routing Triumph 7
dklawson General TR Fuel Line Routing Triumph 4
F Heater pipe and air duct routing BT7 Austin Healey 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR4/4A What is the routing for the speedo cable Triumph 2
G TR4/4A Windshield Washer Tubing Routing Triumph 1
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
CJD TR2/3/3A Overdrive Wire Routing Triumph 15
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
C routing of speedometer cable on BN6? Austin Healey 11
D TR2/3/3A Demisterr vent routing Triumph 6
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
bugedd Fuel Leak and Proper Routing Spridgets 9
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
RAC68 Routing Oil Cooler Lines Austin Healey 16
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
B TR6 Reverse light wiring harness routing Triumph 4
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
tinman58 TR5/TR250 oil line routing Triumph 3
C BJ8 spedo cable routing Austin Healey 2
M Right Hand Drive cable routing Spridgets 11
