Toyota 5 Speed Conversion Questions
Bob McElwee
I am posting this in both the Austin Healey and The Pub forums. It seems to be a popular conversion across different LBC models.
I now have a Toyota 5 speed W58 tranny. I have some questions about it.
1. Is there any way to tell it is a W58 other than putting it in 5th gear and seeing the ratio of the input/output shafts? My highly scientific method indicated an approx .75 input rotation made a 1.0 output rotation. This would support the .783 ration of the W58.
2. Should I just clip the backup light switch wires and pitch the connector?
3. What weight oil and how much? I’ve seen both 2.5 qt and 2.5 L. Any recommended brands?
4. The tranny is supposed to have about 132,000 miles on it. Any maintenance I should do before it goes in the car?
5. When I separated the bell housing one of the alignment dowels stayed in the bell housing. Do I need to get it out and if so, what is a recommended method?
6. Any other hints or tips?
I’m in touch with Pete Delaney for the Smittys conversion kit.
Thanks in advance.
Michael Oritt
I believe there were several different applications for the W58 with varying output ratios but you should find what you have by running down the info on the following sites:
https://ourworld.compuserve.com/homepages/stepho/engcodes.htm
https://users.tpg.com.au/users/loats/technical/ma61/gearboxes.html
https://users.tpg.com.au/users/loats/index.html
https://users.tpg.com.au/users/loats/technical/ma61/gearboxes2.html
I've been told that the R154 is an inferior product--note that its output is close to the W58 but see that there are definite external differences and points of identification.
Yes
I use Redline MTL--there is a filler/level hole on the left side of the transmission--fill till oil comes out.
If it were me I would take it to a transmission shop and have them go through it before going to all the trouble of putting it in, etc.
R
RonMacPherson
Good references.
My two cents. Make sure you get another locating dowel to install. Every little bit of alignment helps.
On the tranny condition. If you take it to a trans shop, strong probablliity they're gonna want to sell you bearings and synchros(and seals) That's a big chunk of change right there.
I recommend draining the oil out, through a paintstrainer. That will help see if there's any detritus in the trans. Then fill and drain again(kind of a flush). Then find someone who's got a healthy drill with a chuck that fits the input shaft. Put it on the shaft and spin it up, run it in each of the e gears(may need to stop the drill and put it in each gear if you don't have the tranny solidly mounted, listen to the trans case, front rear, etc. for any untoward noise check the seals and replace them. These trannys are a very strong unit and most Toyota dealers do not even overhaul them, so be careful choosing a trannyrepairman.
Bob McElwee
Bob McElwee
Thanks Michael and Ron. I'll do some checking to see if anyone knows a repair shop. I had a real bad experience with a national chain one time so I am a little leery about it.
I'll do what I can and use club resources to help.
Keoke
Well yes Ron, it is a bit of change. However, if it were mine and it had 132000 miles on it and it only needed bearings synchros and seals to put it right I would be grateful.-Fwiw---Keoke
R
RonMacPherson
But, it might not need bearings and synchros. Those trannys are usually pretty much bulletproof.
Keoke
Then I would only have to pay for an inspection by a qualified individual and I would be doubly grateful.---Keoke--- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
bighly
Bob,
I only replace the rear seal and shift seat. If the transmission has a problem chuck it and get another.
There are my notes and photos on Smittys (er Pete's) conversion on my website at https://www.bighly.com/.
Cottontop
Hi Bob,
I'm pretty sure that Dick Solomon has put one in one of his cars.
You might contact him. If you don't have his Email addy,
write me out of forum and I'll send it to you.
'Twas good to see you and Jean at Round Up 27. Thanks for coming.
We look forward to seeing you at Tri-Healey.
Tim
Bob McElwee
Bob McElwee
Hi Tim,
Jean and I really enjoy the Texas Round-ups. Gives us a good excuse to fire the car up and take a long trip that will include some neat roads and great people.
The 'sound' we heard when I started the car at the car show was the head pipe gasket getting ready to go. One of the brass nuts had fallen off. By the time we got to Corpus Christi to spend the day with our granddaughter it was pretty noisy. Fortunately it wasn't that bad at highway speed, I could still hear by the time we got home.
We're off to Springthing this weekend - a short trip.
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
Michael Oritt Toyota 5-speed Problem Austin Healey 28
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
Patrick67BJ8 Toyota 5-Speed slides out of 5th gear Austin Healey 19
M Toyota 5 speed Shifter Austin Healey 2
M synthetic fluid in a toyota 5 speed? Triumph 20
prb51 Tr Toyota 5 speed upgrade Triumph 24
gsalt57tr3 TR2/3/3A 5 speed Toyota transmissions in a TR3 Triumph 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR6 Toyota Transmission conversion Triumph 8
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
S '81 Toyota Celica Other Cars 8
aeronca65t One less Toyota 2000 GT Other Cars 5
glemon TR6 Toyota Caliper Conversion Triumph 28
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
aeronca65t Toyota 2000 GT Spotted 9
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
T Question I should know - which rotor for Toyota Triumph 9
Sherlock The ultimate Toyota Land Cruiser? Plus a Jeep too Other Cars 3
T BN1 Toyota Gearbox Austin Healey 4
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
4 Another Toyota Twink Spridgets 13
tinman58 Toyota trans noise Triumph 9
PatGalvin TR2/3/3A Toyota Brake Conversion on a TR3A Triumph 5
PatGalvin Routing brake lines for Toyota 4 pot conversion Triumph 5
T TR4/4A Toyota calipers for a TR4A Triumph 18
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
prb51 Toyota tranny users-Speedo Triumph 15
