Jim_Gruber
Some am I just titling at windmills or is it possible to static time a 948 with the engine in the car and radiator installed. I can't figure out if it is physically possible. One more try at starting after I installed a new set of Points and condenser. They were pitted after leaving ignition turned on overnight but likely still functional. Changed points and condenser out anyway. Guessing the only way to do this if it won't start would be to loosen up the dizzy bolt and try to make some changes till I can see if it will fire. Unless someone has a good alternative strategy.
