Positive Crankcase Hoses
ynotme2
Hey Everyone,
After starting the TC up I noticed I was getting a oil drop under the car. I then traced it down to the dip stick. Oil was coming out of it under a pressure of some sort. Then I noticed that the flex hose from the back of the head was coming around and feeding into the right side of the block (right side when you are at the back of the car and facing the front of it). When I pulled the house the leak stopped. I reasoned that the hose was the PCV. But no valve was there. I noticed on my air filter box that there was an inlet on the back of the box. I assume for the head hose? But does the block outlet on the right side also fed into the air box? Does it require a "T" connection between the 2 hoses to fit into the air box? Any help would be appreciated.
Thanks
Tony
Bruce Bowker
When the hose is pulled are you getting pressure from that hose -can you feel air from it?
Bruce
Bruce Bowker
Which of course indicates there is pressure and that would be going into the crankcase forcing oil out. Question is how much pressure, is it correct and if not where is it coming from?
Have you done a compression check on each cylinder?
Bruce
TypeRboy
I must admit I'm a bit confused about the routing of your vent hose. Sounds like it goes from the head to the block. There shouldn't be any available fitting in the block to hook up a pcv, as the original breather on the Kent block is used as an oil drain for the head ( that's the funny rubber extension between the block and the head on the right rear of the block.) The breather from the right side of the head should go to the fitting on the back of your air filter backing plate. There might be a pcv if the breather hose went directly to a vacume source on the intake manifold
like other cars, but with no serious vacume available from that source on the air filter backing plate, a PCV valve wouldn't work. My hose is just a straight tube with no PCV.
If indeed somehow your breather goes from the head to the block, then that makes it a closed loop system, and would handily explain why the excess crankcase pressure is escaping through the dipstick. ( except for your oil fill cap, there would be no other openings to the atmosphere other than the dipstick.)
Y
ynotme2
Type R,
Thanks for the information. I now understand. The rubber thingy between the head and the block goes to the intake manifold. It looks like my air filter assembly has the hole blocked off. It looks like it was fiberglassed over. Don't know why though. I understand the PO bought the air filter assembly used. I wonder if they blocked it off or it came that way and he didn't know that it was for the breather. I guess I will have to drill a hole in the air filter assembly to fit the hose. Thanks again. I couldn't understand why the hose from the right side of the block as you described was connected to the one at the back of the head of the engine. Didn't make sense to me.
Tony
TypeRboy
I must admit I'm still a little confused from your description of the rubbery thing between the head and the block going to the intake manifold.. That part should be a stand alone piece that simply carries oil draining back from the head to the block, and should have no provision for any venting whatsoever.. The only venting should be from the right side of the head at the rear, and should be a hole in the head just behind the rear most intake port with a grommet and a hose, which goes to the air cleaner backplate. The hose would be quite short and virtually straight. Still, my car is not a Europa, so maybe they are different ( Didn't think so though )
I'm sure you'll figure it out.. Have fun!
Platinum
I've been watching this thread and am confuzzled as well. The downpipe from head to block on T/C engines had no "third" take-off on any one I've ever seen. The crankcase breather was as described by TRB above: 1/2" metal tube through the hole in the side of the head, slight kink in it to allow it to fit into the carb airbox at the back. Both ends sealed via a rubber grommet. IIRC there was a bracket at the airbox end to secure it in place with a bolt, too.
FWIW: I've done a nifty replacement of that oil downpipe on several engines by using the aluminum aftermarket rig that replaces VW pushrod tubes in-situ. Two threaded pieces (one I.D., one O.D.) and "O" rings. Some MacGyverin' is required, but it makes a good positive seal with no leaks and no need to goober up a replacement with RTV and force it into place.
B Positive-Ground LED Light Strip Austin Healey 8
P Positive to Negative Conversion Austin Healey 1
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
M 66 ‘ BJ 8 Positive ground identification Austin Healey 4
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
R TR2/3/3A Positive-ground LED lights Triumph 13
Sopwith_Camel positive camber xj Jaguar 0
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
M TR2/3/3A Positive or negative ground? Triumph 6
P Jump starting a positive ground BJ8 Austin Healey 4
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
K TR2/3/3A Converting to Positive Ground....... Triumph 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
DanLewis Correcting positive camber in a Bugeye Spridgets 21
M LED lamps for Austin Healey with positive ground Austin Healey 0
Lukens What's the down side of "positive ground system"? Triumph 8
P TR4/4A Positive/Negative Earth Dilemma TR4A Triumph 11
P How to use timing light with positive ground? Austin Healey 14
C Positive or Negative Earth Triumph 15
R 66 midget tach positive ground Spridgets 2
Mowgli81 Positive Ground Disconnect in Trunk Austin Healey 4
E Positive ground or Negative ground. What have you? Austin Healey 12
C Positive Ground History with Triumph Motorcycles British Motorbikes 1
Geo Hahn Brakelight Flasher for Positive Ground Triumph 2
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
cbrvfr Running modern accessories with positive ground? Austin Healey 4
S positive and negative ground Triumph 7
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
memphis Positive to Negative Conversion Austin Healey 2
BOBBYR Positive ground dwell Austin Healey 23
PatGalvin Any Issues with Jump Start of Positive Earth LBC Triumph 9
T Why positive ground? Austin Healey 17
S Size 34 Optima Battery w/positive ground Austin Healey 33
J Jump Starting Positive Earth cars. Austin Healey 3
M Jump start positive ground car Austin Healey 10
I Bugeye-better to have negative or positive ground? Spridgets 17
JohnnyMead Relays for Positive Ground Triumph 6
T TR4/4A TR4a positive or negative earth? Triumph 17
