Overflow Catches
GB1
I have a questions regarding overflow catches. The one for the oil that I wish to install is one quart with a breather.
I am a bit confused as to the coolant one. Should it be basically the same without a breather?
And if so does it mater that there is no overflow?
Should it be fille about 1/3 of the way with coolant?
And finally does it mater if they are made out of plastic rather then aluminum?
Please advise.
Thanks,
Patrick
jlaird
Most coolant overflow tanks are plastic Pat.
It should not need an overflow but will need a breather so might as well.
Yep about 1/4 to 1/3 full when cold.
Should think you could find an aftermarket one at most any auto store.
GB1
GB1
Thanks Jack,
You are the best!
I was wondering for maybe some solo laps what I would need, to keep the track dry.
Since, I am installing the breather, I figured why not do them both. Since the mounting space that I forsee is on the left of the radiator (where it attaches the rad support to the fender support) which happens to be where I presently have a 1275 overflow tank mounted.
Patrick
Deleted member 3577
[ QUOTE ]
[/ QUOTE ]
Most are old 1qt. oil containers, pull tied to something w/ duct tape holding the hose in. /ubbthreads/images/graemlins/grin.gif
GB1
GB1
Thanks, so I would be most likely legit with two 1 qt overflow tanks and a breather on the oil?
And the coolant doesn't without a vent?
Thanks,
Patrick
Deleted member 3577
1 for engine
1 for gearbox
1 for rear end
1 for radiator
(or you can combine any number of these)
tony barnhill
Great Pumpkin - R.I.P
[ QUOTE ]
[/ QUOTE ]
& that passes tech inspection?
GB1
GB1
Mounted here is okay,
Rear and gear (same one, ?)
Rad is a sealed unit?
I know it varies....
Sorry stupid!
Plastic is okay?
Patrick
aeronca65t
We (EMRA) only require them for engine and radiator.
One quart oil container for each works fine.
Be sure that you put them in a place where you can easily remove them for dumping. I vent carb overflow into oil tank as well.
[edit]
Plastic is OK.
Rad overflow does not have to be pressure sealed, since normally, it's already coming from sealed expansion tank.
GB1
GB1
Thanks, Nial
Because most likely I be out there with you guys here in the NE. I was going to do one rad and one oils/(Carbs now as per your sugestion). I will have other questions regarding my harness and rollover bar. Is it okay is I pm you?
Just trying to build a multi-purpose car that I can grab a few sole laps on.
Patrick
RobSelina
[ QUOTE ]
[/ QUOTE ]
Wait, so the tank to the right of the radiator on a 1500 doesn't qualify as an overflow/catch can for racing purposes?
As for the oil catch can, anyone have a link to a reasonable looking (something better than a used oil qt container) that's still cheap? Also, where are you guys attaching them, valve cover?
aeronca65t
The remote overflow tank that many cars have might qualify with some clubs. EMRA might let you skate by with one. But I think it would not be OK with SCCA. The overflow tank on most cars has a vent hose...that should go to a catch tank.
There is a bunch of catch cans here:
https://store.summitracing.com/egnsearch.asp?N=115+%2D45755&D=%2D45755
Here's a schematic of my oil catch can. The reason I have it connected to the carb intake is to provide some crankcase vacuum....this effectivley stopped my rear-main seal from leaking (before this, with just a catch-can-to-valve-cover hookup, the rear main would ooze). Not sure if this would work at more moderate (street) RPMs. The spacer is 2" PVC pipe. I am running a single carb as per our club rules for 1500s (S&S 2-1/16" Harley racing-type pumper carb).
GB1
GB1
Thanks to everyone for their greatly needed assistance and knowledgeable answers.
Patrick
JerryB
Poster: tony barnhill
Subject: Re: Overflow Catches
Barely with us.....something like described above will get a notation in the logbook "fix by next race"
We sometimes see this type of thing.."the band aid approach"
but have weeded them out over time. Really funny (well nothings funny on track) is when plastic Home Depot clear tubing is run for motor windage venting and it collapses into jelly.
I use and recommend the thick plastic semi-transparent coolant recovery tanks that are sold in Pep, Autozone etc with the part number of 222 and in a green box...the maker is I forget. Comes with a 2" screw on top and bottom nipple which is perfect for water and a 14 psi double gasket rad cap....water level is visible. For oil you use a separate unit with a grommet and breather in lieu of the cap, and use aluminum bulkhead fittings attached in the side for vent hoses.
There is another nifty one that is plastic and viewable that mounts in a slide bracket....Toyota or Nissan I think....the boneyard yields so many things that crossover...
tony barnhill
Hap - I still like those old Corvette chrome tanks in the Huffaker.
Deleted member 3577
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Here is my Brother's catch can.
This is mine........Engine + radiator go to the old windshield washer fluid container.
The pump discharge tube goes under the car.
If one of those dang Miatas starts irritating me, I can hit the button. /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/devilgrin.gif
Been that way......My log book starts in the early 80's
Here is another one you might like.....
The rear end.
RobSelina
dang, after looking at Hap's photos I have a serious case of engine bay envy! /ubbthreads/images/graemlins/wink.gif
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Radiator Overflow Tank Austin Healey 23
D TR2/3/3A radiator overflow restrictor Triumph 9
G Fuel Overflow Austin Healey 10
tinman58 TR5/TR250 Front carb spitting fuel out overflow Triumph 11
aero3113 Radiator overflow catch tank Austin Healey 15
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
D Overflow Bottle for BT7 Austin Healey 24
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
J New Radiator Cap - Foam overflow Austin Healey 7
britlover Rear SU float not seating -- fuel overflow Austin Healey 24
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
J TR2/3/3A Found my overflow problem from the radiator , Triumph 9
steveg Radiator Cap & overflow system explained Austin Healey 1
K TR2/3/3A TR3A Coolant recovery or overflow setup? Triumph 2
lbc_newbie Float bowl overflow Spridgets 7
Zimmycobra Overflow bottle Triumph 13
H TR6 Filling up the TR6, overflow? Triumph 6
L Bugeye Coolant Overflow Spridgets 8
Jim_Newman Coolant overflow tank for e-type Jaguar 1
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
R SU HS6 Carbs overflow leaking........... MG 20
mrv8q TR2/3/3A TR3 Radiator overflow Q Triumph 4
T Radiator overflow tank? Austin Healey 12
Jim_Gruber SU Carb overflow tubes Spridgets 11
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
CinneaghTR TR4/4A 4A Overflow Bottle Bracket Triumph 19
pjsmetana Spitfire Spitfire Radiator Overflow Bottle Triumph 6
pjsmetana 2 radiator overflow bottles? Triumph 2
Tinkerman TR2/3/3A Radiator overflow pipe clip TR 3A [pics added] Triumph 9
P Manifold and Carb overflow tubes on a BJ7 Austin Healey 18
N Gas from my header overflow Austin Healey 9
M Fuel Tank Overflow Spridgets 5
nevets radiator overflow Austin Healey 16
CCURTISS TR2/3/3A TR3 Coolant coming from overflow Triumph 7
G Overflow bottle a one way deal? Triumph 16
J Fuel Overflow at back float valve Spridgets 2
S Carb Overflow Problem Austin Healey 14
D fuel overflow actually spitting fuel? Spridgets 2
M Coolant Overflow Question... Spridgets 8
KVH Rear Differential Overflow Valve Triumph 3
rick_ingram Coolant loss - overflow only MG 4
jaybird Carb overflow MG 9
R Fuel overflow on XJR Jaguar 1
KVH TR4/4A Odd Radiator Overflow Issue-TR4 Triumph 2
vping Overflow bottle MG 27
C Fuel overflow pipe clips Austin Healey 8
mperdue SU carb plumbing - overflow MG 11
R Carburetors Overflow Austin Healey 4
