OK... The front spring attachment is technically not a bolt -it's a pin. Each end of the pin is D shaped. The outboard side accepts a nut, and a washer with a D shaped hole, which is held in place by a split pin -it keeps the leaf spring/bushing on the pin. The other end of the pin fits (tightly) into a tube in the frame and is kept from rotating by a D shaped fitting at the frame. The larger end of the pin (the d shaped 'bolt' head) ends up on the inboard side of the frame but it has a threaded hole in it for removal.
(as pictured here
https://mossmotors.com/rear-suspension-driveshaft-tr2-4) -your picture shows a glob of paint in the center that almost looks like a grease fitting but is actually a threaded hole.
I helped a fellow owner remove his pins because one side of his car was about 1+1/2" lower. We were able to chase the threads, install a bolt, and with a large c-clamp various spacers, and pry bars we were able to pull the pins out and replace both springs with new. One of the new springs was not made properly, and the locating pin for the axle was rearward about an inch and had to be removed and replaced a second time (the wheel rubbed on the wheel well when lowered). We installed new pins because we felt we might ruin the old ones getting them out. When we were done, we found his car still sits 1+1/2" higher on one side.
The plug on the inner rear fender referenced by John is (IMO) a misunderstanding or bad memory on his part -although I know this to be a very rare occurrence. On the earlier cars with a sloped rear shelf, there is a plug to access the forward shock bolt. That bolt is above the frame rail, and not part of the leaf spring.
Check your new springs closely and be sure the pin (or bolt) for the rear axle is located the same distance on each leaf. I would have a pair of Moss part number 320-230 before I started. While we were replacing stuff with new, we also found one of the new shackles was made incorrectly with one of the pins to large to fit into it's cover.
Good luck, I hope it goes well.
