Rear leaf springs
AUSMHLY
64BJ8. My rear leaf springs are the correct ones (6) they are new from moss. Installed by PO 3 years ago. My car sits 1 1/2" too high. A spring shop told me it would cost about 300-400 to remove, correct them, and reinstall.
I could buy new ones and install them myself cheaper.
There's the risk. Another new set may be right, or make the car too high or too low.
Any suggestions as to where I can purchase a correct set? Or should I have the spring shop work on them.
Thank you, Roger
John Loftus
[ QUOTE ]
[/ QUOTE ]
One way to think about this is the "risk" is only your time for replacing the springs. If they are not right then you can return them hassle-free with Moss (can't say that about all vendors).
Cheers,
John
Dave Russell
Yoda - R.I.P
Are you "sure" it's too high? The phase 2 was designed to sit an inch or so higher than the earlier cars. This would make the distance from ground to the fender edge, measured on the wheel center line, around 28 plus inches.
With brand new springs it's hard to know where they will end up after they have sagged a bit. They will likely drop an inch or more with use. After this period of use it might be hard to return them to the vendor.
I think Keoke suggests taking a leaf or two out to get near the correct ride height, & then adding back if needed, as they settle.
In my experience with a BN2, the now three year old Moss springs were slightly high at first & soon settled to perfect ride height. (27" ground to fender lip).
It is possible to remove spring leaves without disconnecting the main leaf anchor & shackles. You do have to remove & replace the U bolts & the spring center bolt.
Keoke ???????
Keoke
Yep Dave, you have to do the whole nine yards.The main leaf can be left connected.I do not belive you are going to find a set of rear springs for a BJ8 that I know of that will fit off the shelf and establish the correct ride heigth. Roger, If you want to find out how to fit a set look back in the archives when I was guiding[Bless his trust] Greg on setting up a set correctly.An off the shelf new set of BJ8 springs [Based on my experience] will only settle 1/2" after bedding in.---Keoke
Roger,if you want to get it right get it off the jackstands and on the road where the little flaws will shown up and get fixed as you go along.- /ubbthreads/images/graemlins/hammer.gif--Keoke
AUSMHLY
AUSMHLY
Hi Dave, yes, they are an inch and an half higher than they should be, for the bJ8. I have the correct 6 leaf spring. How long or how many miles does it take for them to settle? They have been on the car 3 years, but maybe only 1,000 miles on them. Think they will settle with driving, or should 3 years of the weight of the car have settled them my now.
It would be nice to hear that driving the car will settle them and save me money and time working on it, instead of driving it. I am trying so hard to get her right, before I take her out and show her off. Tring to avoid the, Oh I'll be fixing that later and this and that need to be addressed. If I know about it, I'd prefer to make it right, now. I certainly have learned patience, with the situation at the body shops. Now I have her and she will be finished correctly when she's off the jack stands in my gargae and ready to be driven-enjoyed. I'll just keep plugging away and enjoying it, thanks to the help from the folks here. Roger
Roger, they do settle with time but not sitting at a paint/body shop for 19 months. Are you running proper size tires? Are you phase one or two? '64 was a little unclear on that point. The hight was raised on the phase II. Are both sides equal hight? Have you finnished adding all the stuff into the boot (ie, spare tire, battery,jack,and spares)?
I've been behaving with my Cayenne and haven't needed your services again. Your work sure is nice so I have no doubts you will have the most beautiful BJ8.
AUSMHLY
AUSMHLY
Hi TH. Thanks for taking part in my question, and thanks for the complement. My car. BJ8 phase II. Yes, correct tires and rims. Records from PO, showed he purchased the correct leaf spring pair from Moss. It would seem from the input here, that one would be luck to get a set of leaf springs from any vendor, that did not need to be tweeked.
So, I'll visit the leaf spring specialist and have him do his magic. Thanks all. Roger
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
Keith_M Bugeye rear leaf springs Spridgets 19
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
K TR2/3/3A Moss rear leaf springs? Triumph 19
Jeepster BJ8 rear leaf springs Austin Healey 2
P BJ8 phase 2 rear leaf springs Austin Healey 2
D Replacing rear leaf springs ? Triumph 6
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
tahoe healey re-arching rear leaf springs Austin Healey 27
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
B rear leaf springs Spridgets 14
prb51 Rear Traction Bars for our Leaf springs Triumph 0
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
Michael Oritt BN1 rear leaf springs Austin Healey 4
S Rear Leaf Springs Austin Healey 30
bighly Replacing rear leaf springs Austin Healey 10
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
H rear leaf spring to chassis bushing Austin Healey 11
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
bugedd Rear leaf install Spridgets 7
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
N Rear leaf spring brackets Austin Healey 9
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
8 Rear leaf spring Triumph 3
malice Rear leaf swap. Triumph 8
F new rear leaf spring disapointment... Triumph 9
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
