rear leaf springs
BobS76
While working on my rear brakes, car on stands under the rear axel, I noticed that the left spring is deflected UPWARDS, while the ledt looks OK. My guess is that the spring is shot, nothing to do with the mounting (doesn't sound reasonable, can someone confirm). It does not sound reasonable to replace just one. Does anyone know of a GOOD source for a used set? If I buy new from Moss, it will be expensive enough. But I will then be torn with the temptation to scale upwards for one of the lowered springs. 76 Midget.
Bob Shaw
blkcorvair
sounds bad. while replacing take the spacers out of the front for about 3/4" of drop and put some $20 spacers under the front spring pans. Good to go. I had 1 good used one. Just gave it away. Timing is everything...
Glen_B
Hard to understand how the thick steel sheaves of a spring get "shot", far more likely is a problem with the spring box being rusted out. Unless one or more of the leaves are broken, a large noticeable difference between R and L is going to be the mounting points. To convince yourself, swap the springs and see how things sit. The act of removing them from the car to swap them may expose the real problem.
Glen
The_Mite
Hey Bob,
I'm here in AZ and I've got a good set of used springs from a '65 (5 leafs) and a set from a '70's model with 6 leafs. You can have either set (or both) if you find a problem with yours. Send me an email if you need them.
(The Other) Bob
blkcorvair
by deflecting upwards it sounds like it may have contacted something high while backing up? I have seen this on other small cars, never knew what caused it. Perhaps an impact of a large hole with one wheel or the other of sorts.
LCVDriver
I seem to remember, and it was way back when, I've had this problem before. The springs can flex or hyperextend the opposite way and I had to pull them off of the rear shackle and remount them to get them to flex the right way. The shackle would get pushed the wrong way was how I think it did it....
Maybe it was just some weird 70's dream I had though......
bob
Atrus
oooooohhh - I think I need a set too, and I believe my '68 would have the 5 leaf set! I may be contacting you, Other Bob, if the First Bob doesn't need them!
djk
Not sure how you're counting the springs, but I have a set of 11 springs from a later model sprite (I'm using the original of 13 on my bugeye). If anyone needs them I'm happy to sell them off.
-Debra
tosoutherncars
-Debra
Hehehe, that'd be a heck of a beefy spring, if it was 11 leafs! :wink: DJK, I'm guessing you're referring to the number of coils (front springs)?
I think debra is talking about 1/4 elliptical springs and the original poster was discussing 1/2 elliptical.
PeterC
Duncan, Bugeyes and pre-64 Spridgets have 1/4 elliptical springs. Half the length of your semi-elliptical, and nearly twice the leaves! They just go from the bulkhead to the axle and stop there.
Peter C.
tosoutherncars
Peter C.
Eesh, of course... I'm starting with my 'senior moments' in my 30s! :wink: Just imagine when I hit my 60s...
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
Keith_M Bugeye rear leaf springs Spridgets 19
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
K TR2/3/3A Moss rear leaf springs? Triumph 19
Jeepster BJ8 rear leaf springs Austin Healey 2
P BJ8 phase 2 rear leaf springs Austin Healey 2
D Replacing rear leaf springs ? Triumph 6
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
tahoe healey re-arching rear leaf springs Austin Healey 27
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
prb51 Rear Traction Bars for our Leaf springs Triumph 0
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
AUSMHLY Rear leaf springs Austin Healey 6
Michael Oritt BN1 rear leaf springs Austin Healey 4
S Rear Leaf Springs Austin Healey 30
bighly Replacing rear leaf springs Austin Healey 10
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
H rear leaf spring to chassis bushing Austin Healey 11
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
bugedd Rear leaf install Spridgets 7
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
N Rear leaf spring brackets Austin Healey 9
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
8 Rear leaf spring Triumph 3
malice Rear leaf swap. Triumph 8
F new rear leaf spring disapointment... Triumph 9
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
