TR2/3/3A Leaf springs creaking
DavidApp
My new leaf springs have developed a squeak or creak. Thought something had come lose but found the sound was coming from the springs.
Any thoughts on lubrication for them. I have been advised that petroleum lubricant is not good for the steel used in modern springs.
David
TR3driver
Great Pumpkin - R.I.P
Book says to brush them with used motor oil.
Never heard of any kind of steel not being compatible with motor oil.
TR3driver
Well, I pretty much agree with these guys (or girls): https://www.eng-tips.com/viewthread.cfm?qid=326877
Some springs do have rubber inserts that can degrade when exposed to petroleum. If you have aftermarket springs with inserts, then you should probably look into that.
Otherwise, seems unlikely to me. There doesn't seem to be anything particularly exotic about 5160.
Curiously enough, here is a website that mentions coating 5160 with Vaseline (a petroleum product) to preserve it for long periods.
https://www.katanasale.com/blogs/katanasale/5160-steel
angelfj1
Have the springs been painted so heavily as to prevent lubricant from getting between the individual leaves? No reason to be concerned about dinosaur blood and steel. These cars were designed long before synthetic. If you're concerned, why not use a silicone based lube. You want the leaves to move, slide against each other.
In the old days cars had leaf springs front and rear. The springs were oiled or greased and wrapped with a cloth bandage, like a mummy, or fitted with cloth gaiters. These coverings kept the oil/grease in and the dirt out. Routine maintenance included removing the covering, washing the springs with petrol or "spirit" , re-oiling/greasing and re-wrapping. Not a pleasant job.
DavidApp
They were sprayed with rattle can paint.
Shot some dry lub on them and that seems to have fixed the problem. The Fluid Film was a bit too thick to wick between the leaves.
I did check that the "U" bolts were tight and the shock bolts were tight.
Need to do a road test now.
David
CJD
Every oil change my leafs get a spray and wipe of whatever lubricant is handy. The key is to do it often enough the lube has time to “wick”, as you say.
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
Lin Lubricating Leaf Springs Austin Healey 29
B Disassemble quarter eliptical leaf springs Spridgets 6
Keith_M Bugeye rear leaf springs Spridgets 19
F TR2/3/3A Leaf Springs Triumph 57
D TR2/3/3A New Leaf springs. Triumph 21
C Best Replacement BN1 Leaf Springs Austin Healey 5
J Leaf springs Austin Healey 2
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
GTP1960 TR2/3/3A How long do leaf springs last? Triumph 8
K TR2/3/3A Moss rear leaf springs? Triumph 19
K TR2/3/3A Moss "competition" leaf springs? Triumph 9
RAC68 Quiet Leaf Springs Austin Healey 4
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
N Moss lowered leaf springs Spridgets 4
S Over arched Moss Motors leaf springs for Sprite MkIII Spridgets 33
JimTR4 TR4/4A TR4 leaf springs Triumph 4
Jeepster BJ8 rear leaf springs Austin Healey 2
P BJ8 phase 2 rear leaf springs Austin Healey 2
D Replacing rear leaf springs ? Triumph 6
bugedd Creaky leaf springs Spridgets 14
dougie Why Leaf Springs Fail Austin Healey 22
Superwrench Leaf Springs Austin Healey 10
Ed_K BJ8 leaf springs from Moss have only 5 leafs ? Austin Healey 3
J Leaf Springs Austin Healey 8
T pinion angle and leaf springs Other British Cars 2
D Noise after replacing leaf springs Austin Healey 6
AUSMHLY BJ8 leaf springs Austin Healey 10
bill_powell Leaf Springs [again] Spridgets 15
MadRiver Removing a leaf from leaf springs MG 1
T Leaf Springs Restoration & Tools 8
roscoe BN2 leaf springs Austin Healey 4
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
1 How to remove 1/4 elliptical leaf springs? Spridgets 3
J Defective replacement Leaf Springs? Spridgets 3
tahoe healey re-arching rear leaf springs Austin Healey 27
motofiaccone Leaf Springs Spridgets 11
1 BE 1/4 ellipitical leaf springs Spridgets 4
R Grease leaf springs Austin Healey 4
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
B rear leaf springs Spridgets 14
eschneider who can make british leaf springs??? Other British Cars 9
eschneider custom leaf springs Restoration & Tools 21
prb51 Rear Traction Bars for our Leaf springs Triumph 0
beaulieu powdercoating leaf springs good or bad ? Restoration & Tools 12
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
AUSMHLY Rear leaf springs Austin Healey 6
1 Finished leaf springs + question MG 6
W Leaf Springs ? Austin Healey 9
