TR2/3/3A Moss "competition" leaf springs?
karls59tr
Bronze
It's time to replace the ancient springs on the 3.Anyone have any info on the competition springs? I read somewhere that what they used to do for racing was to remove two of the leaves and replace with a single thicker leaf to stiffen up the spring.
Is this what is done in this application?
I expect you would get better road handling with comp springs but it might accentuate the already bumpy buckboard ride? A trade off? :eagerness:
Jerry
I did not change the springs but did put adjustable tube shocks on the rear of my TR3. Transformed the ride and no more bottom out on big bumps. I would say my TR3A rides better than my wife's Toyota now.
Jerry
K
karls59tr
Bronze
How did you secure the tube shocks to the body? I've heard stories of tube shocks pulling out of the body when that conversion is done to TR4A and TR6's
TomMull
Jerry
Assuming your wife drives a modern Toyota, that is certainly a dramatic improvement. However I think one could expect an improvement, albeit to a lesser degree, by rebuilding or replacing the lever shocks.
Same with the springs, renewing the non-competition standard spring will also improve the ride.
Tom
Jerry
My previous TR3A did have rebuilt lever shocks and they bottomed out at times. This tube shock kit does not allow for the lever shocks to be used in conjuction with the tube shock. The tube shocks for the TR3A must have a bracket welded to the axle housing. This is technically reversible, since you can cut them off and polish up the axle so you won't see it at all. I bought the kit from Rimmer Brothers. I also put adjustable shocks on the front. So the ride is very good. The other improvement was the addition of a front sway bar and Rack and pinon steering. This pretty much takes care of the stuff on my old car that was in need of improvement.
Why a sway bar? My old car would start bouncing on the freeway and it seemed to me that a sway bar would help steady it. The Rack& Pinion was mostly for my wife and daughters as the original steering is stiff. Now it is like power steering. The kit sold does impart bump steer and that must be corrected but it is a good improvement. I think the brand of R&P that Pat Galvin installed is a better choice than mine. It allows you use the original turn signals.
I know some of you prefer to stick to original. I had a car like that and enjoy the drive more now. IE: the car will be driven more.
Jerry
TR3driver
Great Pumpkin - R.I.P
Unless they are really severe bumps, then I'd say any bottoming out is caused by sag in the original springs. New, stock spec springs should not bottom out over any but the most severe bumps.
And stiffer springs have a handling downside on the street as well, since they make the rear wheels tend to skip over the tops of the bumps rather than follow them. Not to mention the effects on kidneys and teeth :smile:
glemon
I have a book about vintage racing British sports cars, it lists the various models, and common, accepted modifications, on one of the cars, the owner talks about actually softening the rear suspension to make the car handle better by removing a leaf, I believe it is either a solid axle TR or a Sprite. I thought that was very interesting, and in relation to the original question, a stock suspension or a TR is plenty stiff, sway bars and shocks are probably better routes to improved handling.
mrv8q
Anyone have thoughts on TRF rear springs? They're on sale this week...
charleyf
I am using TRF leaf springs on both of my TR4's and a TR3B. I noticed on the first set which went on the 3B that there was a issue with the length. I contacted TRF and they replaced them. I understand that after that point they did some checking into what they were getting and improved their stock. Subsequently I have put two sets on the TR 4's. I am happy with them.
Charley
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
D TR2/3/3A Moss alternator kit Triumph 8
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
CessnaTPA Moss Bumpers Austin Healey 21
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
T TR2/3/3A Moss ClassicGold mastrer Cylinder Triumph 18
