TR2/3/3A Should you paint your leaf springs?
GTP1960
I've disassembled the springs and wire brushed them to remove the rust, etc.
but I'm wondering should I paint them & if so what's the best way?
all leafs; all sides?
just the sides, bottom & top?(after they are greased reassembled and cleaned ?)
not at all?
Pat stated he uses red axle grease between the leafs, that stuff doesn't mix with paint to well.
thx
Rut
I disassembled my Bugeye leaf springs, wire brushed and blasted all the rust away, cleaned them thoroughly to make sure no grit was left and primed the individual leaves with a good self etching primer. I then top coated them with a good chassis black paint, let dry and sprayed each leaf with SlipPlate graphite paint. This provides all the lubrication without grit attracting oil or grease and looks really good. Very happy with the results.
Rut
https://www.slipplate.com/product/slip-plate-aerosol
GTP1960
GTP1960
Thx Rut,
I ordered the slip plate penetrator stuff.
Btw: their marketing dept. Has me convenienced I should drink this stuff!
GP
Rut
They actually market their original product for use on farm implements to help grain move thru the chute faster! It's also great for painting things like master cylinders, etc. where you want a cast iron look that brake fluid doesn't remove.
Rut
PeterK
I use Sliplate on my tractor stuff. You actually need to burnish the dried coating with a fine wire brush to make it slick (instructions). On a mower deck it will hold up all season before it get scoured off. I buy it by the quart. Stir very well, then stir some more as the solids sink to the bottom of the can. I think Tractor Supply Co sells it in the store.
It might even be too slippery for spring leaves. I use paint on my springs then use a small chip brush to push oil in sideways once in a while.
CJD
I've always done mine the way the factory did...build the spring bare and paint it as a unit.
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
B Healey for sale should I paint or not? Austin Healey 6
B What type of paint should I use on my restoration? Restoration & Tools 2
J what kind of paint[s] should I use Triumph 7
kennypinkerton What paint gun should I use? Restoration & Tools 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
S Well, this should be interesting..... Other Cars 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
M TR4/4A Where should TR4A carpet snaps be placed? Triumph 10
J TR4/4A 1965 TR4 in pieces, What should we do with it? Triumph 9
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
JPSmit Bring a Trailer should be banned Other British Cars 3
M How well should the water pump free spin? Spridgets 4
C What should the VIN plate look like for a BN1? Austin Healey 1
N Spitfire Should this be bent? Triumph 4
