G
Assuming I now have the dizzy installed correctly, how can I static time or figure out where the first ignition point is on the dizzy. I run the car at 8*BTDC normally with no vacuum advance (using centrifugal advance). Where should I set the pulley pointer and where should I set the rotor cap? Make sense?
