philman
finally finished on my '76 tr7 dhc intake manifold gasket r/r, now it runs only as long as the starter is engaged. release the key and the engine dies. got fuel at carbs, swapped out sparkies and wires no difference. previous owner had installed an allison electronic ignition and lucas sportcoil. any ideas? i read about 1.5 volts on the coil "+" terminal with key on (motor not running). is that normal? thanks
