Ignition / Coil Wiring Question
G
First off: Newbie here with a 1980 B
Related pix: https://www.scaledatacom.com/mgb/
The car has what I think is an electronic ignition (noted in Pic 3). I think this is a replacement as my car has the taped-off group of wht,wht/blu and wht/blk wires that other folks have which indicates the original elec ignition was swapped out for this newer one.
From this ignition box are 5 wires:
red goes to + on coil
black goes to - on coil
purple is ground
bundle of 1 wht and 1 blk wire go directly into distriubutor.
There are 2 connectors that I think were nudged loose by me while futzing in the engine bay but I'm not 100% sure and don't want to connect them if they're not supposed to be conncted. Pic 5 illustrates this.
Basically, I'm trying to figure out if the wht/grn wires should be conncted to the the wht/blk wires given the current ignition setup the car has.
Thanks in advance for any help!
77blueblunder
Member
Jamie,
Given that someone apparently "cut-in" an aftermarket electronic ignition kit, it's kind of hard to tell exactly whats going on but here's my try. Refering to your attached diagram, the green/white wires were originally part of the ballast/resistor/coil/solenoid wiring loop. On one side of the ballast/resistor was the wht/blue and the other side was the white wire that connects to your cut-off wht/green wire. The connector you show in your diagram on the two wht/green wires originally went to + terminal on the Coil. Do you have a wiring diagram? If you don't - Get one ASAP. Also from your attached pictures I dont see the wht/Blk wires connected. Does your Tachometer work? The wht/black wires originally connected to the negative terminal on the coil - one controls the Tach the other goes to the distributor. Of course that's how it was originally. Hope this helps!! 77blueblunder
I remebered that the white/black wire goes to the tach, but not where it originated.... It'll be time for an oil change soon... I may snap a pic then.
77blueblunder
Member
You also need to look at the coil. The original coil was a 1.5 ohm and required the use of the ballast/resistor. The way yours is wired the ballast/resistor system has been bypassed. You may have a 3.0 ohm coil. In any event as long as the car runs good with the electronic ignition that is on it, I would only be concerned with hooking up wht/blk wires to get the tach working.
PAUL161
Looks like one of those units that Whitney used to sell. How about a photo inside of the dizzy, with the rotor out? /ubbthreads/images/graemlins/crazyeyes.gifPJ
G
77BlueBlunder, I do have a wiring diagram but my car doesn't match up because of this cut-in system.
The car isn't running as I'm waiting to see if the wht/blk wht/grn wires should be connected. I didn't want to start the car and have something fry.
I'm pretty sure the wht/blk wire group wasn't connect to the coil the last time the car was running as the wires were no where near the coil when I started working on it.
The question is: should the group of wht/blk be connected to the wht/grn group (where the 2 red question marks are)?
I think they may have been connected last time the car was running but I think I nudged them loose while futzing in the engine bay as few weeks back. Or, could I do any damage by connecting the wht/blk group to the neg on the coil and the wht/grn to the pos on the coil given there is a new ignition setup now?
Thanks all...any info is more than I have /ubbthreads/images/graemlins/smile.gif
77blueblunder
Member
Jamie,
How long has the car been sitting?
Since the car will not run, looking again at your diagram, it does not look like you have any power going to the coil. Try connecing the white/green wire connector to the + side of the coil and the wht/black connector to the - side. Pull one of the spark plugs and have someone turn the engine over while you ground it against the block. Do you have a Spark? if so that is good. Replace the plug and try to start.
If not, connect the cut wht/grn wire to the cut white wire you show in the taped bundle. Try the spark plug test again. If you have a spark now you can replace the plug and try to start the engine. If this doesn't get you going send me an email. /ubbthreads/images/graemlins/hammer.gif
Platinum
ummm... all but one plug in a hole is asking for a facefull of problems. It'll START on three holes firing...
I'd say sit with a VOM and find hot leads with the iggy on, figure which goes to coil. Purple ground sounds like a...umm... "X700" someting-or-other solid state system. Not a bad way to go, but: using voltages and ohms is a more prudent method that "spinnin' 'er up" with parts of the system still connected. A good diagram is kinda helpful too. If memory serves, there is a white wire to the tach, not a white/black. That indicates a "trigger" circuit.
...where's that bloody PDF when ya need it....
77blueblunder
Member
Yea your'e right about the one plug out . I thought about that after I sent it. better to use a spark tester or pull all of the plugs.
I did check the stock wiring diagram the wht/blk does go to the tach. There's a good PDF wiring diagram on the Advance Auto Wire web site.
thanks for the correction.
Platinum
THAT's the PDF I was huntin'. EARLY car here, white to tach as an induction pulse, and couldn't find th' reference quickly. Good on ya!
Keoke
Hi Jamiebo, I think the GRN&WHT wires connect to the BLK & WHT ones. However, this still leaves the ignition circuit unpowered. It would seem necessary to connect the Ballast resistor which is by passed by the blue and white wire to the NEG terminal of the coil.-Fwiw--Keoke-AZ- /ubbthreads/images/graemlins/cowboy.gif
G
Car was running perfect a month ago...then I swapped out battery, main battery positive cable (old one was crapola), changed oil, filters etc...Now car will turn over but not start. I think I nudged some of the wht/grn and wht blk wires from their prospective connections while under the hood and don't know where to connect them now.
I've been told by some to connect the wht/blk to the neg on coil and wht/grn to pos on coil...and others say they none of them should be connected to the coil and should all be taped off.
Figure 5 in this Lucas diagram closely resembles my config:
www.scaledatacom.com/mgb/diagram.jpg
In the diagram, wht/grn are taped off and not used...which makes me wonder: where is the coil getting power from?
Any help/recommendations would be great. she turns over but will not fire up.
Keoke
That is my concern also there is no power to the coil as shown. I took a good look at the second drawing you provided and if that agrees with your configuration it seems to me to be correct. If you have an Ohm Meter measure the resistance of the coil, if it is much greater than 1.5 Ohms,say about 3ohms the PO may have replaced the coil with an unbalasted one and starting may still be a chore if wired as indicated in the second drawing---Keoke
Check it out and let us know how you get on
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
jsneddon Ignition Coil Wiring Triumph 2
Cokerair TR4/4A Fried Ignition Coil Triumph 18
F Hot Ignition Coil Austin Healey 6
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
TulsaFred Ignition / Ignition coil problem Spridgets 10
M ignition coil high tension lead connection Spridgets 10
Lukens TR2/3/3A Back to my ignition coil education Triumph 2
CJD TR2/3/3A "Big" ignition coil Triumph 12
A TR2/3/3A Correct Coil for petronix ignition tr3A Triumph 2
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
C Rear seat panel BJ7 & ignition coil help Austin Healey 14
NutmegCT Ignition coil resistance Triumph 8
S Lucas Sport ignition coil Triumph 29
A TR2/3/3A WHAT IGNITION COIL TO BUY FOR MY 59 TR3 Triumph 10
C Ignition coil question Triumph 4
I Bugeye ignition coil wire help Spridgets 7
G Lost spark [ Best ignition coil for a stock '79] Spridgets 18
angelfj1 TR2/3/3A Lucas Ignition Coil for TR3A Triumph 1
T overheated ignition coil ? Triumph 21
MGTF1250Dave Ignition Coil Low Tension Connections Triumph 12
R spark plug gap with pertronix ignition and coil Spridgets 6
B Ignition Coil Mounting Spridgets 6
S Ignition, coil recommendations? Spridgets 9
eschneider ignition coil oil ? Triumph 11
8 IGNITION COIL Triumph 1
V TR6 TR6 ignition coil polarity Triumph 3
VictorVictor ignition coil Spridgets 17
martx-5 TR2/3/3A TR3 Ignition Coil Triumph 5
zimmy Pertronix coil and ignition system Spridgets 8
Editor_Reid Ignition Coil Nomenclature Austin Healey 7
ronzet AH 100-6 Ignition coil polarity POSITIVE EARTH Austin Healey 15
AUSMHLY Pertronix ignition and coil Austin Healey 4
G TR5/TR250 TR250/6 ignition coil Triumph 5
Cain Short in Ignition Coil? Triumph 5
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 7
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
