MGB 1977 MGB Ignition Coil and Wiring.
YesImDoug
Hey guys,
I recently purchased a 1977 MGB. Let me say, the wiring is a complete mess, I don't even know where to start.
I wish I could upload pictures right now, but I can't.. (Will edit some in later if needed)
I want some help, I don't exactly know what wires should be going to this Ignition Coil. Currently there's only one wire on it, and it's a ground.
Coil, plugs, and distributor are all new.
I was told the ignition coil is the only thing not causing the engine to start (It cranks, no spark ofc) Is there any way to by-pass this just to hear it started? Also, does anyone have pictures of how a properly wired Ignition Coil looks like? Maybe some good wiring diagrams, any advice would be appreciated!
Thanks,
Doug
Mickey Richaud
Hi, Doug, and welcome to the BCF!
First, check here for your wiring diagram; scroll down to find your year model: https://www.advanceautowire.com/mgb.pdf
Once you've done that and hooked up the proper wires get back to us and let us know what happens.
Mickey
Y
YesImDoug
Hi Mickey,
Thank you for the welcome, also for the wiring diagram, that makes it so much easier. Do you happen to also have a picture of a Coil Properly wired? I like to have something visual I can follow the diagram with first then tackle mine!
I'll be doing this, this weekend.. Sucks working 8 am - 8 pm in Canada... dark when I leave, dark when I come home :(
Thanks,
Doug
Mickey Richaud
Sorry - not near my cars at present. But if you Google MGB ignition coil images you'll get plenty of pictures. Hopefully, someone hasn't replaced or switched wire colors on you...
:cheers:
Mickey
Sarastro
The coil has two low-voltage terminals. One goes to the points on the distributor, the other needs +12V. The latter should be switched; i.e., turned on and off with the ignition switch.
For testing, you can just run a wire from the battery. This is called "hot wiring" the car.
I forget how the coil terminals are labeled. The coil does have a polarity (i.e., a particular terminal has to be connected to the distributor and the other to the +12V), but it's not all that important. The car will run even if you get it backwards.
Joe Reed
I *think* your '77 has the same ignition setup as the '78....a ballasted ignition. If so, you should have two white/black wires on the negative post (one supplies the signal to the tach, the other goes to the distributor). The positive post has two white/green wires. One feeds power to the coil directly from the starter solenoid. The other feeds power to the coil as well, but through either a ballast resistor or a resistor wire.
If you do have the ballast resistor wiring, the wire direct from the starter solenoid energizes the coil when the ignition is in the "start" position. This supplies full battery voltage to the coil for a hotter spark. When the switch is returned to the "run" position, the coil is supplied via the resistor wire...reducing the voltage to the coil.
The coil for the ballasted system is a 1.5 ohm coil (measured across the + and - terminals). The one for the non-ballasted system is a 3 ohm coil. If you have only one white/green wire, your system is non-ballasted and should have a 3 ohm coil. If a 1.5 ohm coil was run continuously on a direct 12v supply it would kill the coil Lots of cars that were originally ballasted have been converted when converting the original ignition to some other type, and converted to a 3 ohm coil in the process.
Hope this helps get you started!
Mark af
Hi Joe, thanks for your explanation. I have a 1977 MGB with messed up wiring. The green white from the starter is intact. The "run" wire has been cobbled into a splice and is sending 12 volts to the coil. There is a hot, but cut green white white near the coil, but it is also testing at 12 volts. There is also a cut white wire at 12 volts. I have an original Opus set up, with an old 1.5 ohm coil. Originally, do you know how the resistance ignition wires ran? Was it all white? Or white into green white? Or green white into white?
I put an aftermarket resistor in front of the coil, but it made little difference. Thanks, Mark
Joe Reed
I'll try to help, but I'm no expert - and my car hasn't had an Opus system since sometime in the last century. :smile: Someone smarter than I am will probably be along later to correct any of my errors.
I'll start with the easiest part. The negative side of the coil should have two white/black wires. One of these goes to the center position of the plug to the distributor. The other goes to the tachometer.
The positive side of the coil would have two white/light green wires. One comes directly from the starter solenoid. The other is where it gets a little more complicated. That white/light green wire at some point becomes the ballast wire (maybe a pink wire?) that goes forward in the harness, then makes a U-turn back toward the distributor. The length of that wire is what provides the resistance required.
That ballast wire (I believe) goes to a 4-way connector. There should be 3 white wires at that same connector.
One goes to position #5 on the fuse box (second from the bottom on the left side as you face the box).
One goes to the distributor resistor, where is exits as a white/blue wire that goes to the left side of the plug at the distributor (as you face the end of the plug from the top, looking toward the distributor).
The third white wire goes directly to the other side of that plug (right side).
This arrangement (of course) is assuming that a PO hasn't been creative elsewhere in the wiring.
I hope this at least leads you in the right direction.
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
C T-Series 1977 MGB ignition switch MG 4
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
kyreb1862 MGB 1977 MGB MG 9
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B 1977 Midget Bra Spridgets 9
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
T MGB-GT 1977 MG BGT electrical MG 6
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
