MGB What size is the steering wheel on a 1977 MGB?
QuickSilver
I am trying to order am aftermarket wheel and my car is not here at work.
Thanks.
Platinum
Re: What is the sie of the steering wheel on a 77?
I like a 14" on MGBs, better leg clearance and enuff leverage at low speeds ya don't need to be a gorilla to maneuver it. Anything bigger is intrusive to the legroom and ingress/egress. Spridgets can get away with 13" but it gets to be "tedious" in a B.
QuickSilver
QuickSilver
A thousand apologies. It's a 77 MGB.
Platinum
I knew that. :wink:
Platinum
On a '77 I believe so, but not sure. One of the purists will likely have the definitive answer. ISTR earlier cars had 16"!!!
tony barnhill
Great Pumpkin - R.I.P
Stock is 15"....I go with 14" Tourist Trophy steering wheels on all mine.
QuickSilver
QuickSilver
Thank you Messrs Tony and Entropy.
As you are.
Platinum
Where th' heck you been? Not too waterlogged I hope.
GeorgeC Steering wheel nut size? Spridgets 3
Jim_Gruber Steering Wheel but size for BE Spridgets 5
S Correct Size Steering Wheel Austin Healey 1
M steering wheel nut size. Triumph 10
bill_powell Steering Wheel Boss Size Spridgets 5
budk1953 Steering wheel nut size Spridgets 2
Bruce_B Size of Nut for Steering Wheel..driver not include Spridgets 6
emann Steering Wheel Thread Size Spridgets 11
kch Steering wheel size-opinions Austin Healey 19
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
Rut TR4/4A steering shaft/nut thread size Triumph 5
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
ChrisS Steering Rack Outer Tie Rod End Size Spridgets 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Bayless What size battery for my '67 Sprite? Spridgets 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
S TR2/3/3A Vacuum Advance Union Size Triumph 1
T Radiator Hose Size Austin Healey 2
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
B Exhaust Pipe Size Austin Healey 26
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
Healey Nut TR6 Headlight size Triumph 58
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
B TR4/4A Oil Drain plug size Triumph 14
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
69MGC MGC What size tires will fit nicely MG 2
M TR5/TR250 Compatible Modern Tire Size Triumph 5
J Nut size for BJ8 center console trim piece Austin Healey 8
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
D TR4/4A SU HS6 throttle spindle size Triumph 20
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
Bayless What size fuel line for '67 Sprite? Spridgets 2
S Bugeye Radiator Tank Plug Size? Spridgets 24
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
K Abington Allocation Plate size? Austin Healey 1
R TR4/4A Door mirror base size Triumph 2
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
S TR2/3/3A Pixel primmer size Triumph 18
F TR2/3/3A Spare Tire Size Triumph 11
