1977 MG HELP!!! Fluid issue
jsladovich
I'm new to MG's. I don't know the exact issue of my friends 1977 MG. He states that the car has sat for a year, and he has never been rebuilt the engine. He also claims that the oil is now white and the consistency of a glue, not good. what could this possibly be? Did coolant leak into the oil somehow? Is it the oil that sat and this is the result?
2nd question, does anyone have any ideas, tricks, thoughts on how to rebuild a 1977 MG engine? Thanks.
If you would like to post here, fine, but if you could send me your response to jsladovich@hotmail.com that would be great.
Keoke
HI Jsladovich, If the oil is greenish its OK, If its Black its ok. But if its white or grey it suggests that water has gotten in to the oil from someplace and that is not OK!. The oil should be drained out immediately and fresh oil put in. I have no tricks to contribute to overhauling an engine its pretty straight forward though. Others may provide guidance on the forum if required.---Fwiw---Keoke /ubbthreads/images/graemlins/driving.gif
J
jsladovich
Where do you think water could have come in from? I don't know these motors very well. I'm not a furtune teller, but I see a rebuild in my future.
What can you do to these cars to perk them up in performance? Anyone have any ideas about:
Cams
Air/Fuel
Port Polish
Valve Job
Exhaust
Gearing
Thanks.
Keoke
OH , I would guess the most likely point would be the head gasket.Or a crack in the head itself.---Keoke?? /ubbthreads/images/graemlins/iagree.gif Rebuild is possible.
usasma
How to Power Tune MGB 4-Cylinder Engines by Peter Burgess.
He recommends:
Cylinder head conversion/tuning
Air Filters (such as K&N)
Camshaft change
Performance Exhaust
Electronic Ignition
Carburation Tuning (?sp)
and Rolling Road Tuning
There's lot's more info in the book - it includes a number of "power recipes" for different situations and effort.
G
Amazon.com has the Peter Burgess book for $19.01. He has others too just put his name on the search at Amazon.
J
jsladovich
Well, we drained the oil out of the engine and the lower end had oil just like house paint. It had some regular colored oil and some white in color. There was not much in the head, although I'm sure that this is the source of the water leak.
does anyone know about the coolant lines in the exhaust manifold? Where could water/coolant leak in from other than a crack or a bad head gasket? Anywhere? We are going to replace all the seals we can now. Anyone have any advice for engine rebuilds and what cam sets or mods to do that are cheap?
LLAngus
If you have water in the oil you need to find out where it comes from before you start and drive your car. If not you will be in danger of a complete rebuild and not just a head gasket change. The head gasket is easy to change on these motors. Just follow a good manual. I also, recommend (as others have) that you get a catalog form Moss or Victoria. They are great for how items go together as well as parts. I have rebuilt my daughter's motor and they are a long weekend job if you are patience. Good Luck.
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B 1977 Midget Bra Spridgets 9
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
T MGB-GT 1977 MG BGT electrical MG 6
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
kyreb1862 MGB 1977 MGB MG 9
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
