MGB 1977 MGB
kyreb1862
Looks like I'm finally ready to close the deal on this "B" I've been after. My plans at this point are to get it home and change all the fluids. Including draining and refilling the cooling system. Draining and refilling the hydraulic's. Draining and refilling the engine, trainsmission and differential. I also plan on pulling the wheels and checking the pads and shoes. I also plan on plugs, plug wires, distributor cap, fuel and air filters and a valve adjustment. Can anyone fill me in on anything else that needs to be looked at before I put the "B" on the road? /ubbthreads/images/graemlins/driving.gif
jsneddon
tony barnhill
Great Pumpkin - R.I.P
Jim - me either....hehehehe
John - if you follow my checklist, you'll have her ready to go in no time...there might be some items you don't need to check but I tried to cover most everything.
kyreb1862
kyreb1862
Thanks for the input Tony. The car is already running this much I know already so I'm going to take your checklist and give it a good going over especially the braking system. Would you recommend repacking the front wheel bearings during this process? /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/thumbsup.gif
jlaird
Good idea, costs nothing and good insurance.
tony barnhill
Absolutely! Does it have wire wheels? If so take them off, cleah the splines in the wheels & on the hubs & coat with white lithium grease.
kyreb1862
kyreb1862
No wires. It has the rostyle wheels. Going to replace them with some type of alloy as soon as finances will allow. Mechanicals first. /ubbthreads/images/graemlins/driving.gif
quibix
Oh, yes! Make sure to pull the plungers out of the carbs & top up the reservoirs with motor oil. Without that, even after you've done everything else, that car is going exactly nowhere!
J
Going nowhere? My MGB has covered only 88,000 miles in the past (nearly) 30 years! That's 31.6 trips back n fro - from NY, NY to LA, CA!!! It spent almost ten of those years sitting under a carport and a shed. So - That's an average of 4630 or so miles a year (during it's running years)... Not much mind you, but it's still the best road car I own! And granted, I've only logged about 5000 miles on it since I bought it 2 or 3 years ago, but.... Going exactly nowhere? It's been across the country more times than I have!!!! I guess I didn't get the statement.
By the way welcome to the forums!!!!
Excellent car, the 1977 MGB is. I'd like to have a couple more. /ubbthreads/images/graemlins/thumbsup.gif
tony barnhill
[ QUOTE ]
[/ QUOTE ]
Automatic Transmission fluid - 20W50 is too thick!
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B 1977 Midget Bra Spridgets 9
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
T MGB-GT 1977 MG BGT electrical MG 6
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
