T-Series 1977 MGB ignition switch
cfiaime
Greetings,
During a recent move from the Milwaukee area to Denver I (gasp!) lost the key for my 1977 MGB Roadster. Yes, I had only one key, and that was sufficient during the rebuild (which is not yet done, but that is another story).
Now the question: how hard is it to get the current ignition switch / column lock re-keyed, or am I about to spend $180 or so for a new assembly?
Oh, by the way, I truly appreciated the earlier threads about how to remove the lock mechanism using a Dremel tool.
jeff williams - cfiaime@cfiaime.com
Kimberly
Not hard at all. Remove the cowl. There is a screw holding the ignition switch to the lock. Remove the screw and the switch will slide out of the lock, now the car can be started with a screwdriver. To remove the lock, slot the two shear bolts and use a big screwdriver to remove the lock from the column. Take the lock to a locksmith and have a couple of keys made. You can use a couple of cap screws to replace the bolts if you want.
Should take about half an hour.
tony barnhill
Great Pumpkin - R.I.P
If the locksmith doesn't have key blanks, you can get them from Moss...
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
kyreb1862 MGB 1977 MGB MG 9
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B 1977 Midget Bra Spridgets 9
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
T MGB-GT 1977 MG BGT electrical MG 6
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
