OT: Value Of A 1977 MG B Engine & Transmission
QuickSilver
I want to offer this up before I yank it out so that the buyer can judge the running condition, which is fantastic.
This will be an all inclusive deal, alternator, weber carbs, headers, starter, the whole shebangs.
So what's a fair price?
bob67bgt
In my opinion all you can tell by hearing it run is that it is a good core. Unless you have put several hundred miles on it and can advise the oil consumption and true hot oil pressure its a gamble. I started a MGB engine in my 73 that has been sitting for 25 years. Sounds great and good oil pressure. Compression is within 2 lbs of 140 on all 4. Having no history on the oil mileage i will be tearing it down for a rebuild. Also hard to look at the cam and lifters without tearing into it. I guess what i am saying is lots more info is needed to determine a fair price. Also look close for a external head crack. I look forward to other opinions on this topic. Bob
QuickSilver
QuickSilver
I've put in almost 2 thousand miles on the car.
Surely an engine that is driven is a far better bet than one that the owner just claims that "it ran when I pulled it".
Maybe it won't matter but I just wanted a general idea of a price.
C TR2/3/3A Frame repair and value Triumph 2
D I have doubled the value of my MG Midget. Spridgets 2
AngliaGT 1275 Engine Value? Spridgets 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
HealeyRick Gold Level Concours Value Austin Healey 20
M Original Bugeye steering wheel value Spridgets 3
Kleykamp Rubber bumper Midget value? Spridgets 5
K TR2/3/3A Value of a Complete Motor disassembled? Triumph 8
J 1963 Austin Healy "Sprite" Value Austin Healey 7
J MGB 1973 MGB Value MG 8
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
TR4nut TR6 Ballpark hardtop value? Anyone? Triumph 3
D 68 Sprite value - need help Austin Healey 9
TomMull GT6 More on value trends Triumph 12
Brinkerhoff TR6 value of a TR6 factory hardtop Triumph 5
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
M The value in 5 speed conversion Spridgets 18
7 TR6 help with tr6 hardtop value Triumph 5
B Original Hardtop - Identification and Value Austin Healey 8
C Value of 100-4 heater box?? Austin Healey 2
J TR2/3/3A Dynamic timing value Triumph 5
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
Gliderman8 TR6 Opinions on value of this '76 TR6 Triumph 18
C Color change...impact on Value? Austin Healey 24
Mink TR4/4A Your thoughts/value of this TR4 Triumph 357
Jim_Stevens TR2/3/3A OD Transmission value Triumph 3
AngliaGT MGB '67 B - Value? MG 5
T 100-6 Longbridge value Austin Healey 5
2 GT6 69 GT6+ suggested value? Triumph 4
J Value on an original BJ7 these days. ?? 38,000 miles Austin Healey 4
RickB MK1 Midge radiator value? Spridgets 2
apbos Works hardtop. The value of or cars is climbing! Spridgets 11
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
Brinkerhoff Market value for an unrestored BJ7 ? Austin Healey 17
K Value of an early Commission Number Triumph 5
N BT7 Restoration value advice Austin Healey 32
6 any value to this?? MG 2
TR4A_IRS TR4/4A TR4A long block value? Triumph 11
C BJ8 Smoothline top value Austin Healey 9
Marvin Gruber Looking at another 100 6- value? Austin Healey 16
R Fair Market Value Triumph 15
J Things that influence the value of a Spridget? Spridgets 18
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
A T-Series MG TD Barn Find [sort of] value MG 1
