MGB-GT 1977 MG BGT electrical
tufsis
Hi all, hope someone out there can help me. I have just got an MG, with a few problems, but this one is baffling me. I have fitted a new battery, and when I turn on the ignition, the warning light is very very dim, but gets slightly brighter the longer it stays on. If I then start the car, it really missfires. It has an alternator and is neg earth. Any help appreciated.
Thanks
Jon
philman
any more clues? try putting a meter on the battery while the engine is running and checking the voltage. then turn on all the accessories and check the voltage.
gjoakes
Jon,
Based on this my first guess would be dirty or loose battery terminals. If they check out then start working your way forward. Checking voltages with a meter at various points would be helpful if you can compare the no-load and under-load readings.
Good luck ...
Greg Oakes
Kimberly
Wiring diagrams are available at https://www.advanceautowire.com click on stock schematics
Make yourself a couple of enlarged copies, one for reference, and one to make notes on.
Start at the battery, verifying voltage output and making sure all the battery cable connections (four of them if you have one battery) are clean and secure. Check all the connections that are accessible under the bonnet, making sure they are clean and secure. Note which connectors you have inspected and cleaned on your diagram.
Check the belt tension
Measure the output of the alternator at idle and at 2000rpms. Verify you aren't having charging problems.
Provide the model year of your car. The ignition light will stay on if the alternator is not charging. The ignition light being dim and then getting brighter can be indicative of high resistant (corroded) connections. Clean or replace connectors and use dielectric grease to prevent future corrosion.
T
tufsis
Thank you all very much, I will be having a look tomorrow, but the info given is already very helpful
Thanks again
Jon
T
tufsis
Hi everyone,
Managed to get time to look at the MG over the weekend, and have sorted out a few other electrical problems, but this one is still hanging on. When the ignition is turned on, the charge light is very dim, but when it is started, the charge light becomes much brighter, and does not go out, but the engine runs fine. I feel as if it could be the alternator at fault, but how do I test this????
When I put a meter across the battery, it shows over 12v, and when the engine is running, it almost seems to count down slightly. Any feedback greatly appreciated.
Thanks
Jon
R
RonMacPherson
Please explain count down slightly.
Battery, fully charged voltage should be 12.6 volts, anything over 12.2 is acceptable.
when your engine is running with no accessories, lights, blowers, radio off. at 1500+ rpm you should be running 13.5 possibly up to 14.7 volts. If at idle the charging voltage drops below 12 volts, you either have an enormous draw(in which case your battery would be completely dead as it is being drained) or your charging system has failed.(i.e., alternator)
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B 1977 Midget Bra Spridgets 9
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
kyreb1862 MGB 1977 MGB MG 9
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
DNK MGB-GT Bgt v8 MG 6
Mickey Richaud '67 BGT Spotted 0
RickB MGB-GT 67 BGT on Portland Craigslist MG 0
