MGB Tail lights do not work- 1977
muhrich
The tail lights, rear parking and license plate lights on my 1977 MGB work intermittently. The head lights and brake lights work fine. Any idea the problem. I am guessing there is a problem with the lamp switch on the steering housing.
Mickey Richaud
First thing to check ~always~ is ground. If I'm not mistaken, there's a common ground point back there for those lights. Take a look along the back panel and you should find a grouping of black wires. Check that connection - loosen the screw and clean up all contact points and see how that does.
And welcome to the party here!
:cheers:
Mickey
WillR
Open your boot. Look straight down and you will see two nuts holding your license plate mount to the body. The drivers side is where the grounds are attached. That "should" be the ground for those lights. I have a 78 B opened up in the garage now. Thats the only reason I could tell you where. Your lucky, tomorrows the day I start to pull all my wiring out. Then I would have had to keep my mouth shut for fear of making a fool out of myself.
Welcome to the BCF! Were looking at moving to portland in about a year for my wife's masters program. How do you like it?
bob67bgt
If its the HL switch the parking lights in the front would also not be working. The rear lights have separate wires off the fuse box for each side. I guess it could also be a fuse making contact some times and not other times. If the ground was bad at the license plate the fuel pump gets its ground there. No mention of a non running car. (if the fuel pump and wires are as original) Bob
Sarastro
This is one of those times when "bad grounds" is not just a one-size-fits-all solution to electrical problems. Seems highly likely to me.
This would be a good time to buy a cheap multimeter, or at least a test lamp, and start practicing troubleshooting--trace through the circuit to see where you are losing voltage. Check for voltage at the lamps, and if they have no voltage, continue up the circuit toward the source and see where you are losing it.
By the way, don't assume that the problem isn't simple. Are the bulbs OK? Are the socket contacts clean? Seems unlikely that more than one bulb would die at one time, but coincidences do happen sometimes.
WillR
"Practicing" is a good term for it. I feel like I learn some thing new every time I pick that tool up.
muhrich, whats your progress?
Platinum
Look to the Lucar connectors at the firewall on the passenger side. Specifically the green, green/white and green/red wires.
bob67bgt
Green/white right signal, green /red left signal. Green just keyed power. Red circuit for tail lights. Fuse box probably just dirty at the red terminals. Marker lights have a blue wire that plugs into red at the rear of the car.
dbster
Also, see if they work when headlights are on, or just don't work at all. That bolt behind the license plate others have mentioned as a ground point - clean up the connectors and the actual part of the body they screw down on. Also possibly the flasher could be bad.
O Spitfire Tail lights not working Triumph 6
drooartz MGB Early tail lights on later car MG 17
JFS Wedge Brake and Tail lights Triumph 3
R bugeye tail lights Spridgets 6
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
F TR2/3/3A Tail Lights Triumph 3
bigbadbluetr6 TR6 Rear tail lights not working. Triumph 17
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
D Help! No tail lights or sidemarkers Jaguar 14
bighealeysource LED tail lights for Healey's and most Brit cars Austin Healey 7
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
B Tail lights/blinkers Spridgets 3
QuickSilver Let's Talk Tail Lights MG 7
B How to install tail and parking lights?? Austin Healey 10
Webb Tail Lights Out Triumph 12
Bruce Bowker Round tail lights TVR 4
T Designer tail lights for Amos Triumph 30
Lin Tail lights and turn signals Austin Healey 4
B 3000 MKII [BJ7] Tail lights not working Austin Healey 2
Raymond Dim tail/ Brake Lights MG 32
I TR6 TR6- water leaking through tail lights Triumph 4
RickB How to 'fix' under the tail lights? on a 78 midget Spridgets 15
zimmy tail lights Spridgets 4
R Brake & Tail Lights NONE! Austin Healey 3
J Left tail, marker, plate lights [fan Latest too] MG 19
R Tail lights Austin Healey 2
wkilleffer Trouble with tail lights and rear sidemarkers MG 18
D Dim tail lights Triumph 5
F XJ8 Tail Lights do not work Jaguar 0
J No Tail Lights Spridgets 6
A Tail Lights wiring Spridgets 3
D Wedge TR7 Tail Lights Triumph 2
A Early Two Piece Tail Lights MG 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
D TR2/3/3A 3D printed tail light Triumph 12
bigjones TR2/3/3A Rear tail light not budging Triumph 5
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
T Tail light extension Spridgets 2
C MGA R/H tail lamp removal on a 1962 MG 5
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
N Wanted Early rear tail light lens Triumph Classifieds 0
S TR2/3/3A Aluminum tail pipe section Triumph 3
L TR2/3/3A Rear tail light cutouts Triumph 213
G For Sale Round-tail Spit-6 Project car with OD for Sale [Cambria CA] Triumph Classifieds 0
B Stop/Tail light wiring Austin Healey 23
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
RandyInUtah Wanted TR3 Original Tail light lens Triumph Classifieds 1
