MGB 1977 MGB Intake
kyreb1862
I seem to remember reading once that you could cut out the intake section of a RB one piece manifold. If I did that, would the intake section still be usable with an exhaust header? I still have some ideas for the single carb set up but I want to be able to lose the cat and go with a less restrictive exhaust manifold.
AlanT
Sounds like you want an Austin Marina set-up. It uses a single sidedraft (CD175 of HIF6) and a dual downpipe ala MGB.
Alan T
ccougill
I've seen it done but I can't remember if it was necessary to fab a cover or not. Tony will chime in soon I hope
kyreb1862
kyreb1862
Alan T
Where could I come up with such a set up?
Actually, you can put an HIF6 on the existing MGB combo manifold. I ran one on my 1978 MGB for several years.;
Granted, exhaust flow was still forced to do some crazy escape patterns....but it was somewhat better performing than the ZS175...and made for a GREAT conversation piece.
tony barnhill
Great Pumpkin - R.I.P
Yep, whack the intake off the exhaust & toss the exhaust...use the intake with either the ZS carb or one of the larger carbs (HS-6, I think)...use an early MGB exhaust or a Peco header....
Bret
Hmm? Ya know I was thinking about doing this too. The emissions legal EFI kit from Moss bypasses the EGR valve and that's the only reason to use the stock intake/exhaust manifold.
Not that emissions is a concern for John, but I could use a short header and attach a aftermarket catalytic converter. I believe Magnflow or someone like that makes what's called a "pre-cat" (for two stage or duel cat systems) that would work better than the original and less restrictive.
Shouldn't affect tail pipe emissions part of the test. But I wonder if it'd get flagged by the inspectors when they performed the under the bonnet inspection.
Might not be an issue. Especially given the fact that half the time the test tech's at the state run "Smog Test Only" stations can't even locate the cat on their own.
kyreb1862
kyreb1862
Now I just got to get me a look at an Austin Marina intake manifold. I need to determine the mounting flange thickness on either the Austin Marina intake or the cut off MGB intake so I can determine what brand header I can use. Luckily emissions inspections are not something I have to deal with.
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
kyreb1862 MGB 1977 MGB MG 9
A MGB 1977 MGB Antenna Installation??? MG 4
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B 1977 Midget Bra Spridgets 9
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
T MGB-GT 1977 MG BGT electrical MG 6
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
