Ignition question
John_Mc
Here's my second post of three for the evening.
When I turn my ignition key counterclockwise, the starter runs but there is no ignition. Is this an electrical glitch (ie should the ignition key NOT be able to turn counterclockwise) or is this intentional design, perhaps to be used to turn and lubricate a cold engine without starting combustion? Again, thanks in advance for any input.
G
Geez, John, I think you are reading into that ignition question. Sounds like your ignition is broken. I don't think it is designed to do just that. Mine doesn't turn left at all.
Hmmmmm.
Bill
Adrio
My TR4A ignition does turn left. But it does not turn on the starter when I do that. Without looking at the wire diagram but from memory when I put the wire loome in the car, I think the left turn is just for accessories and powers up everything except the ignition. This is so that the points don't wear out if you want the car electics on without the engine running. My guess is you have the input wire for your starter solenoid going to both the start and accessory posts of your key switch.
Geo Hahn
TR4 ignition also has the accessory position -- TR6 owners might re-check theirs as it seems odd they would add this useful feature, then drop it.
Mis-wired is one way, faulty switch is another.
RomanH
The accessory position on the 6 ignition is one click to the right from "OFF". The key should not be able to be turned counter clockwise from the off position.
The order of operation is 1) OFF 2) ACCESSORY 3) RUN 4) START.
Clockwise of course.
Andrew Mace
Roman-H is correct for the steering column lock/ignition switch. But the others are, I believe, also right for a 1969 TR6 and earlier TR4/4A. Granted, I'm not intimately familiar with ignition switches on the earliest TR4s, but other Triumphs with "FP" series keys did not have accessory positions on the ignition switch (said switch having screw terminals), but later cars with "FS" keys did (said switch having "Lucar" spade terminals).
Of course, those with sidescreen cars couldn't even start their cars with the key alone; they also needed to push the starter button or spin the "starting handle" (crank). /ubbthreads/images/graemlins/grin.gif
SherpaPilot TR6 Ignition Switch Question Triumph 13
Lin Ignition timing question Spridgets 2
Lin 123 Ignition Question Austin Healey 0
catfood BN1 Ignition question. Austin Healey 14
charleyf TR6 distributor--ignition question Triumph 5
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
longbridgehealey New Bugeye ignition switch question Spridgets 10
nevets BN6 ignition parts question Austin Healey 3
T TR4/4A TR4A ignition switch question Triumph 19
C Ignition coil question Triumph 4
T TR4/4A TR4a ignition switch question Triumph 5
G ignition key/lock switch question Spridgets 0
Monark192 Ignition Switch / Steering Lock Removal Question Spridgets 1
Ohiobugeye Pertronix Ignition Question Spridgets 7
Got_All_4 TR2/3/3A TR3A Ignition Problem / Question Triumph 11
N MGB Question about ignition wiring unique to 1980 MGB MG 15
RobT Pre-Ignition [Pinging] Question Triumph 21
G Ignition question. Triumph 5
T Ignition parts question Triumph 23
M Another Ignition Timing Question Austin Healey 8
tosoutherncars Crane ignition question Spridgets 15
Atrus Yes, another electronic ignition question Spridgets 2
Atrus Crane/Pertronix Ignition Question Spridgets 11
D Ignition Question [Ultimate Dummy Question] Spridgets 10
Morris 'nother ignition question Spridgets 2
F Re: crane xr 700 optic ignition system question MG 10
T Question on ignition switch wiring Triumph 10
TNMGB Steering wheel lock and ignition question... MG 11
N Ignition Opinion Question MG 21
G Ignition / Coil Wiring Question MG 12
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
S Ignition question MG 5
txtr3 basic ignition timing question Triumph 3
EMGEBE MGB MGB Ignition question MG 9
philman Wedge ignition question tr7 Triumph 6
B Pertronix ignition question MG 12
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 7
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
