Hello
My BT7 has started to backfire on deceleration. I would like to check the timing as this is most likely the cause. I have a timing light with no advance dial etc. I have located the notch on the pulley and used some chalk to highlight it and removed the vacuum pipe. When I check the timing the notch is about two inches or so to the left of the pointer (looking from the front) at idle. Now my question is - do I need to adjust the distributor so the notch and the pointer line up at idle?
Thanks for your help.
Myles
Myles
