CJD
I am sure you are right. The plug would be necessary to hold the pressure in the pump, and to provide a grip to remove the pump for a rebuild.
As far as ID'ing the tranny, the stamped serial number would likely give a clue. The overdrive label is normally under the shifter lever, and difficult to read. The mystery may have to wait until the next rebuild...knock on wood!
