question after testing a J type overdrive
71MKIV
I just tested the J o/d transmission I bought for my Spitfire.
At first it didn't want to disengage, but after playing with it for awhile it started to behave correctly.
Now the question:
Using the buckeye triumph webpage write up as a model the pressure guage responded just like I hoped it would except for one thing:
There was a pressure fluxuation of about 50 lbs with it engaged, from about 425 down to about 375 or so.
To me that means one or a combination of three things,
Leaky pump,
Leaky pressure relief valve,
Leaky operating piston.
My question then:
Worry about it? or let it go?
Thanks
R
RonMacPherson
I'd drop the screen and check for gunk buildup. Maybe pop the relief valve out and clean it up... Other than that, it's building good pressure. And your symptom description alludes to some gunk hanging up..
TR3driver
Great Pumpkin - R.I.P
For a Spit, the working pressure should only be 320-350 psi.
Personally, I would want to chase down the problem, as it sounds like a sticking PRV. That may also be the reason it didn't want to drop out of OD at one point; excess pressure can jam the clutches together until the springs won't separate them or of course the PRV itself can stick in the OD position. The clearances in the PRV are very tight, so the least little bit of swarf can cause problems. And if it sticks, the pressure may spike well above what you read.
Backing up with the unit stuck in OD will damage it badly, basically causing the sprag clutch to break and take the rear housing with it.
Note that there are two screens worthy of cleaning. You have to remove a plug to get to the pressure side screen.
Brosky
Just out of curiosity, what did the oil look like that came out of it when you got it? Was it clean and how did the strainer look?
TR3driver
This might be helpful
71MKIV
Here's the story,
About a year and a half ago I was reading the Classic Motorsports forum, when a fella from TX wrote in that there was a o/d equipped Spitfire in the scrapyard next to him.
I wrote him and we worked a deal for him to pull the whole gearbox and ship it to me.
When I got it he had drained it, so I don't know what the old oil looked like.
I pulled the top cover and everything was very clean, the synchro's are hardly worn at all, everything turned smoothly.
I pulled the o/d pan and pulled the HP screen, it was all very clean.
I removed the solenoid and tested it on the bench, it worked.
I put a new o ring on it and reinstalled it.
I dumped a quart of 30W in it, and made an adapter to drive the input shaft with a electric motor that I had laying around.
Just for fun, I tried it without a pressure gauge, and it would engage, but would not disengage without stopping it.
I made another adapter so I could put a pressure guage on it, and tried again.
Which lead to the first post. The more I play with it the more readily it disengages, to the point that it disengages almost immediatly.
My question is how concerned should I be over the pressure fluctuations?
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
R TR6 Starter wiring question Triumph 6
K TR2/3/3A TR-3B carb question Triumph 13
