General TR Overdrive Up-date and Clutch Question
KVH
Overdrive Update and Clutch Question
My OD is working great after replacing that side plate and readjusting the operating valve. Very smooth. But my clutch is now engaging at the very bottom. It’s not right. It’s a good clutch barely used. I think it’s a combination of slave cylinder adjustment and proper bleeding to remove air. What advice can I get there? My one-man Griott’s bleeding tool using compressed air baffles me, and I’m not confident the “Venturi” sucking theory is working the way some lady friend’s foot might!
BTW—that .032 lift measurement seems more precise than the 3/16th bit trick for valve adjustment, and that’s likely due to the parts wear you folks mentioned.
TR3driver
Great Pumpkin - R.I.P
Re: Overdrive Update and Clutch Question
My advice: Get the slave adjusted first. If it's way out of whack, look for what's wrong. Usually, they go a long, long time without needing adjustment.
Then I normally just let the clutch self-bleed. Pump it up, hold a few seconds, then release and wait a few seconds. 3 reps of that should get good clutch. Then drive it a few days to get the last little bit out.
Unlike the brakes, the clutch line doesn't have a lot of ups and downs to trap air.
KVH
KVH
OK thx I’ll get back on it. I’ll bet I didn’t get that adjustment correct.
bighealeysource Up-date on BN2 overdrive problem Austin Healey 9
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
G Misc Questions re Overdrive and Exhaust + Up-date on Redline Oil Austin Healey 7
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
