Hello all --
My overdrive has been slow to engage (and sometimes slips) when hot. I thought I had licked the problem with heavyweight oil and an operating valve adjustment a few years ago (which did help enormously), but it seems unhappy again on hot days at slow speeds....
Measured cold (with 50 weight oil), I got ~275 psi @ 1500 RPM in 4th. I then a) replaced the spring on the non-return valve, b) replaced the accumulator spring, and c) added a 1/16" washer in the accumulator piston.
Now (cold, still with 50 weight oil) I get ~510 psi @ 1500 RPM (and ~540 psi @ 3000 RPM) -- guess I didn't need the washer! -- BUT, the pressure now drops rapidly to zero as soon as I stop the transmission spinning.
I assume either the operating valve isn't seating or I messed up the accumulator piston rings? Fiddling with the former didn't seem to help, and how bad can the accumulator rings be if I'm seeing >500 PSI?
So I guess my question is, should I care? Everthing seems happy (at least on jackstands), except for the pressure dropping quickly. Or any troubleshooting ideas?
Thank you ever so much!
