TR4/4A TR4 Transmission Question [non overdrive]
TR3TR6
I rebuilt a TR4 transmission, replaced the bearings, seals and everything else that showed any wear. Installed it in my TR3A and in worked good for about a year and then it started popping out of 2nd gear. Any suggestions as to what to check or look for? I've looked at the synchro's, and they look good.
TR3driver
Great Pumpkin - R.I.P
Aka "bush, 2nd gear". Located on the mainshaft, with 2nd gear riding on it.
They also seem to frequently be sized wrong.
tdskip
Randall - wrong size as in replacement parts are the wrong size? Any ideas on correct ones?
(no vendor bashing intent, just trying to help)
TR3TR6
TR3TR6
Thanks Randall. That part isn't cheap. I noticed that Moss has a two-piece steel replacement for more bucks. Is that pretty common for that bronze bushing to crack? If the bushing checks out okay, is there anything else that will cause 2nd gear to pop out that your aware of? Thanks.
sail
I recall some top hat replacements need adjustment to fit the spec for gear float.
An easier one to fix would be if the selector shafts tension springs are too loose.
TR3driver
Yes, wrong size as in the replacement parts do not fit correctly. I've heard that both from other people, and had it happen to me. The bushes are supposed to move easily on the shaft, and the gear move on the bush. Then the bush is supposed to be slightly longer than the gear. I went through 3 or 4 of each, then finally wound up reusing the old one in one case, and lapping the new one out larger for the other one.
Sorry, no idea on who has the right ones. I got the impression that this is one of those situations where all the parts originally came from the same source, and it's simply luck of the draw whether you get a good one or not.
The top hat breaking was a common enough problem that the factory started using steel instead of bronze in the late TR6 boxes. ISTR they also used the 2-piece steel bush for awhile, perhaps in early Stags.
Excess float on the mainshaft can cause problems, which in turn could be caused by the big circlip breaking or popping out of it's groove. I would also double-check that the alignment dowels between gearbox and engine are in place, although that's not a common problem with TR3s.
Check the TRF TR6 parts book, it has a page on mismatched gearbox components. Friend of mine had a very persistent problem with popping out of 2nd, that was eventually traced to mis-matched components being used by a rebuilder.
I don't know of anything else, but I'm still a neophyte when it comes to transmissions. You could try giving Herman van den Akker a call; although I don't know if he is still willing to talk about TR boxes or not.
vivdownunder
Occasionally the spring that holds the detent ball into the notch in the 1st/2nd selector shaft breaks, or needs tightening a touch. Check that the selector fork isn't bent and its fixing is secure.
Avoid push/tow starting the car in second gear. The jolt when dropping the clutch is a suspect for broken 2nd gear top hat bushes.
Viv.
sail
From The Greasy Hands Guide:
"The detents and springs are probably the most important parts in the top cover. If these are not working properly, the transmission can jump out of gear, with 2nd gear being the most common problem."
Greasy Hands Guide Reassembly
I'm no expert but worth a shot, better than taking the whole thing apart again if you don't need to. You can feel this adjustment through the shift lever although you must take the cover off to adjust. Then get a fish scale and measure it. I added a washer with one of the springs to get the correct release. FYI I reused my top hat bushing with a mix of new and existing spacers. Daunting project.
TR4nut
I put one of these steel ones in a few months ago when I rebuilt my gearbox for the 3A. Not sure it is worth the price, but I will say the fit was excellent, I had purchased a bronze one and can confirm it had fit issues - couldn't even get it on the gear/mainshaft properly.
TR3TR6
TR3TR6
Thanks everyone, I will report back on what I find problem wise, after I tear into it again.
J TR4/4A Odd TR4 transmission question Triumph 10
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
J TR4/4A TR4 Transmission question Triumph 7
D TR4/4A Automatic transmission in a TR4 A Triumph 13
J TR4/4A Answer to my post "help with tr4 transmission disassembly". Triumph 9
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
F TR4/4A TR4 shifter and transmission tunnel Triumph 4
KVH TR4/4A TR4 Transmission Cover: The Three Big Triumph 7
K TR4/4A TR4 &4A transmission counterweight? Triumph 2
Mark_Barton TR4/4A Trying to replace TR4 transmission mount Triumph 13
S TR4/4A TR4 Transmission Problem Triumph 5
Lucas63 TR4/4A TR4 Engine and Transmission Weight Triumph 5
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
