Naomi, what Bill should be looking out for are parts rainng down...LOL, no not quite that bad. Study the manual and find out what you may expect to see. plug, o-ring, pump body and spring/plunger. plunger may hang up and have to be fiddled down seperate.
Dissmantling it is fairly straight forward. Re-installing the pump assy is a bit more awkward. Plunger at the top (roller end has a flat on it, make sure that it facing the correct direction. While you have the pump out check that the cam on the output shaft (works the pump plunger) make sure it is not freewheeling on the shaft. I prefer to position the cam in its uppermost position when installing the pump assy, takes some of the pressure off the spring and makes it easier to screw in the retaining plug
Cheers Ric
