Overdrive transmission question
JKB1957
I am trying to adjust the O/D on my Spitfire MK2. It has a "D" type O/D. I have the inspection plate off and cannot fit the 3/16's rod into the O/D, so I am pretty sure it needs to be adjusted. But here's my question. With the ignition on, and in fourth gear, when I flick the O/D switch the relay clicks but the solenoid piston doesn't move. Should the solenoid piston being moving when I move the switch to the on position?
TR3driver
Great Pumpkin - R.I.P
Yup, solenoid should move. Sounds like you've got a bum solenoid, or a wiring problem.
What happens if you grab the lever with the 3/16" hole, and try to push it forward so the holes line up?
J
JKB1957
I can move the piston easily back and forth, so I can line the holes up fine. I can't get the adjustment nut to turn on the piston, so I was going to pull the solenoid so I have more room to work on the adjustment nut. The O/D had been working, but then starting working intermitently on the last drive before finally packing it in.
TR3driver
Just a thought, I would double-check that the solenoid is actually getting power. The relay leads a hard life anyway, and just because it clicks doesn't mean it's contacts are good.
After having several of them fail within a few months, I added a diode to help protect the relay contacts (on an A-type, but the relay & solenoid are the same).
J
JKB1957
Did a check last night. I have power from the relay to the solenoid when the switch is on. Ordered a new solenoid this morning from Nigel over at Spitbits. Thanks for the help.
TR3TR6 TR4/4A TR4 Transmission Question [non overdrive] Triumph 11
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
J Transmission and Overdrive Rebuild Austin Healey 6
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
KVH TR4/4A Transmission and Overdrive Capacity Triumph 6
G Transmission with Overdrive - Which Oil to Use Austin Healey 30
Moosca TR2/3/3A TR3 Overdrive Transmission Verification Triumph 5
Marvin Gruber General TR Overdrive transmission serial number Triumph 1
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
L Transmission BN2 with 28/1292 overdrive Austin Healey 3
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
W TR2/3/3A Looking Into Overdrive Transmission Triumph 16
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
S TR2/3/3A overdrive transmission, cosmetically clean Triumph 12
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
AUSMHLY Flushing the transmission and overdrive Austin Healey 6
drooartz Servicing transmission and overdrive MG 9
KVH TR4/4A TR4A Transmission Overdrive Plug Leak Triumph 13
John_Mc MG overdrive transmission on CL MG 2
N Seating The Ball On An Overdrive Transmission MG 10
5 Water in overdrive and transmission Austin Healey 4
Johnny Removing Overdrive from transmission. Austin Healey 1
V a type overdrive transmission Triumph 8
C Transmission conversion for overdrive what to do? Austin Healey 15
Mickey Richaud Transmission/Overdrive Wiring MG 3
6 Overdrive Transmission MG 16
7 Overdrive Transmission MG 1
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
