Recently acquired a 56 BN2 that has not run for 20 years. I started changing fluids and the 4 speed transmission is full of oil and water. I mean a lot of water. I think someone intentionally or unintentionally filled the transmission with water. I have drained the gooey fluid and removed the side cover on the transmission and cleaned it. Everything inside looked in good condition once the water and oil was removed. No rust and gears look to be in excellent condition. I then removed the drain plug on the overdrive and the same gooey mixture was in the screen. My question is it possible to flush the overdrive? Or do I need to remove the overdrive and disassemble? Can the overdrive be removed without removing the transmission?
