Water pump
Lin
Not too long ago there was some discussion here about replacement water pumps. I think it was generated by the advertisement AH Spares put out about their new after market pump.
Yesterday I noticed some chirping at the front of the engine at idle. Couldn’t really tell if it was the alternator or the water pump. However, after the engine cooled down I grabbed opposing fan blades and found that I could rock the water pump pulley and fan back and forth ever so slightly. Not much at all mind you, but there is definitely movement. Pump is working just fine and no leaks but I fear the bushing is shot and that means that there is a new water pump in my future. The installed pump is a County pump not the original. If it was the original, I would ask M. Salter for a rebuild, but alas it is not. It is a press on, not secured by a nut.
So, what about the new AH Spares pump? I am aware of the fact that it has the odd combination of a sealed bushing (bearing?) while also providing a lubrication point. Has anyone actually purchased, installed and used one of these pumps? Everything fit just right? Pleased with the product?
Any other thoughts or suggestions. How long do you think I have before I am on life-support? Is this one of those noisy irritants that requires attention in 4-6 weeks or is it the type that suggests I should stop driving the car until I get it replaced?
Thanks for any thoughts.
Lin
red57
Lin,
Are you sure its a County pump? Not all of the OEM pumps have pulleys secured by a nut - some are/were press on. I don't remember the era breakdowns off the top of my head but I rebuilt mine a few months ago with bearings & seal I got from Michael Salter and mine is definitely a press on pully. His website has some detail info on identifying characteristics of the pumps - https://www.netbug.net/blogmichael/?s=water+pump
I have no recent experience with new pumps. I suggest you look for an OEM and get parts from Michael - with his blog and parts, mine was really quite easy to rebuild (disclaimer - I'm still waiting for my block & head to come back from the machine shop so can't claim complete success with the water pump just yet :smile:).
Dave
Madflyer
Did you put some wax or bar soap on fan belt it might be glassed belt they also have water additives as pump lube. I would say find the problem and fix it, is 't most likely raining any way in FL I live in Nevada it never rains here so sour grapes on my part Madflyer
Keoke
Lin :
Generally speaking if the part say's County it bound to fail'-LOL
However , my opinion is get it rebuilt by a known good USA rebuilder like White Post or talk to Healey surgeons . JMOP
I agree with red 57. Find an old original and rebuild it. I have about 7 years on a Country pump so I carry the original rebuilt in the boot. If it is Country I believe it will say it on the "tube" that the hose connects to. Rather stupid on their part as it is raised lettering and I had to grind it flat the get the best hose fit.
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
T TR2/3/3A Moss uprated water pump Triumph 6
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
George Zeck Water Pump ? Spridgets 5
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
D TR2/3/3A TR3 water pump question Triumph 4
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
G Water Pump Failure - Diagnostic Steps? Austin Healey 16
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
Got_All_4 TR2/3/3A Water pump problem Triumph 7
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
C Healey BN6 water pump and overheating problems Austin Healey 11
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
histerical Water Pump Spridgets 1
D TR4/4A water pump mystery hole Triumph 6
T TR2/3/3A Water Pump Housing Bypass Triumph 11
B TR2/3/3A end of me water pump thread Triumph 2
B TR2/3/3A Replacement or rebuild kit for water pump Triumph 11
B TR2/3/3A Water pump color Triumph 4
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
matmire Replacement Water pump issue Spridgets 5
2 TR2/3/3A Classic Gold TR2-4 water pump Triumph 5
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
Got_All_4 TR2/3/3A Water pump dissasembly Triumph 10
L Trouble refitting pulley to new water pump Spridgets 9
JFS TR2/3/3A Bad Water Pump Triumph 11
tomshobby replacing water pump Spridgets 1
