TR2/3/3A Bad Water Pump
JFS
Bronze
My new water pump from TRF doesn't fit. The three mounting holes do not line up. The old pump came off easily and goes back on just as easily . The old pump has PC11A in the casting, the new one has LUCAS in its casting and the sticker on the box says made in Taiwan. . Visually, it looks the same. I called TRF's service number and was given a tech dept. number to call, but no one answers. I have dealt with TRF since Charles began his business and have always received good products and good service; I hope this is an anomaly.
TR3driver
Great Pumpkin - R.I.P
Did you try it in all 3 orientations? The holes are not evenly spaced, it only fits one way. The pump I got from TRF a few years back fit fine, but I don't recall it saying 'Lucas' on it.
I would try calling back the service number (actually any number that answers the phone) and insisting on being transferred to someone that can help you. If they give you any grief, ask to talk to Albert or John Swauger (sp?).
JFS
JFS
Bronze
Randall, I tried it with the weep hole at the bottom like the old one was mounted. I"ll pull the pulley to change the single bolt and see if that makes a difference. I'll also call TRF again.
Geo Hahn
On the original pumps the correct position was more obvious because you had to have the grease zerk on top. On the repros I have seen (that lack the zerk) the boss for it was still there in the casting and is a clue to orientation.
JFS
JFS
Bronze
Found that the pump DOES FIT with the weep hole on the passenger right side. This does not locate the grease zerk casting in the same location as the previous pump either. I got through to the TRF tech line and was told that the weep hole orientation makes no difference. (I still think a bottom drain hole makes more sense. I should have trial fit it before inserting the bolt and pressing on the pulley.) So, I did NOT get a bad water pump from TRF.
charleyf
TR3driver;101424u. If they give you any grief said:
Randall,
FYI JOhn Swauger retired about six months ago. Leaving Albert as the day time manager.
Charley
TR3driver
Thanks, Charley, I didn't know that. I wish John all the best, but it's a shame to lose his knowledge and wisdom.
But even if he is not available, I suspect that just asking for him would still impress the low-level person who answers the phone.
I forgot about that stupid bolt; replaced mine with a stud many years ago when I was using one of the aftermarket pumps with integral pulley.
TR4nut
Randall,
Charley
And I think Dave Hagenbuch retired around November last year as well.
Popeye
Bronze
The retirements worry me; however it seems TRF has some good "younger" blood. I've been there a few times to pick up parts, and they seem to have some steady folks without gray hair that answer the phone. And while not as technically experienced as Albert, John and Dave, they still seem to know their stuff (information tends to agree with what I find searching BCF, for example). I hope they grow with the company and especially support the "reverse engineering" projects at TRF.
TomMull
I know that I raise an issue that has been flogged to death many times but I'll resurrect it anyway. It makes no difference because they have pallet loads of them cast up or drilled out in the wrong orientation. I'm not bashing TRF, this seems to be the the way things are done across the industry in general. These same reproduction pumps are available from a variety of sources. Will it work? Sure it will, but is it right? Not in my opinion. The dilemma, or excuse, depending on how you look at it, is that a proper rebuilt, or a kit for that matter, is three times the price, if you can get one.
A note with the pump, explaining the orientation, would have been nice too, since a bolt has to go in before the pulley goes on. Of course, that would only work if these replacement pumps were not oriented randomly.
I do wonder how much more it would have cost to get these right?
Tom
Geo Hahn
...I do wonder how much more it would have cost to get these right?
I don't know, but likely the figure would be expressed in Yuans.
It is a conundrum as customers' shopping behavior encourages vendors to compete on price and something has to give to make that happen.
charleyf
Tom
Tom,
And now you come to the Investment program at TRF. Charles uses part of that money to engineer accurate parts to either replace parts like being discussed here or parts that people want but the molds have been lost. etc.. So by letting TRF know that particular part that they may be selling is not correct it can get elevated to the list of those that need new production. But the cost is high so that has to come into it. A good example is the TR3/4 fuel pump sold by TRF. Lots of problems with the new pumps out so TRF reengineered it back to original looks and functioning. Unfortunately the cost is really high but the pump is supposed to be very reliable. Time will tell if the gamble of redoing the pump will pay for itself. Will people pay the higher price to get a reliable fuel pump or will they go for the cheaper one. Or in my case will they rebuild the older ones.
No I do not work for TRF, but I am an investor with them. I do buy most of my parts from them, but I do look at the price of parts at Moss as well and do buy occasionally from them.
Charley
TulsaFred Bad water pump Spridgets 1
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
Dave Richards Water Choke...good, or bad? MG 5
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A Now the bad news. BRAKES Triumph 7
S TR2/3/3A How bad is this? Vertical link Triumph 12
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
roscoe Good news/bad news Austin Healey 11
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
C TR6 Frame Pics, some bad news Triumph 9
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
gbtr6 TR6 Good news, Bad news Triumph 10
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Sixpack TR6 Bad Oil Leak Triumph 24
tinman58 TR2/3/3A Bad thinking? Triumph 25
Geo Hahn TR2/3/3A Bad Day in the Garage Triumph 23
tinman58 General Tech Bad spark plugs Triumph 7
J The Good the Bad and the Ugly Lotus 4
DanLewis How bad does your Bugeye need a boot? Spridgets 6
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
D Spitfire '65 Spitfire MKII w/bad vibes Triumph 4
T is my generator bad? Austin Healey 5
T TR2/3/3A Sticker idea; good or bad? Triumph 11
pkmh Distributor rotor gone bad more than once. Austin Healey 5
PAUL161 Moss Motors T Series Parts - Bad Gaskets! MG 5
Boggsy64 MGB Brit are bad engineers MG 17
M My '65 suddenly started running bad today Spridgets 37
HealeyRick Bad Day on the Hill in NZ Austin Healey 7
bertl Bad Surgery Triumph 7
J Bad News 1098 Spridgets 14
John_Mc Probably just a bad ground somewhere... Triumph 1
I Effect of bad valves on engine performance? Triumph 9
