TR6 Fresh rebuild gone bad!!!!!!!
moneypit6
I dropped my tr6 off at a shop for engine rebuild among other things. 7 1/2 months later I get my car back. First off,,,,the clutch is squeezing when the pedal is push down. So I called the shop owner,,,,he tells me it's a brass washer/bushing that takes time to wear in. I'd say it's the throw out bearing.
secondly,,,,,I kept a close eye on the engine oil level. This past Sunday with 388 miles on it the oil was in between the marks on the dip stick,,,,so I take a drive,,,upon my return home,,,I have put about another 150 miles on the tr6 , I check the oil once again,,,,,it took a full quart to fill up to the spot on the dip stick . Now, I'm no expert,,,but,, a fresh engine in my mind should not burn a quart of oil in 150 miles. Feeling somewhat angry to say the least.
i work hard for my pay cheque....and paid one third my years salary for the repairs on my car. Yeah,,,it's fair to say I'm alittle more than upset at this point .
malbaby
Do you live near Scarborough...I have a friend there that has a very nice TR250 and is very knowledgeable on TR's, and may be able to advise you.
CJD
I wouldn't sweat the oil burn if the car only has 500 miles on it...although I might take a look at the crankcase breather system to make sure it's not building back pressure or sucking oil into it at highway speeds.
M_Pied_Lourd
What shop did you take it to?
Cheers
Tush
LarryK
My friend took his 1953 MK7 Jag engine to a shop for rebuild at $1000s. 500 miles later oil was gushing everywhere. And then he broke his supposedly rebuilt 4- speed. Shop had engine for a year. Tranny shop had trans a month. I repulled engine and tranny, rebuilt engine for $736 in parts, no labor fees, did all the old fashion hand work and found another tranny and kept main housing and redid tranny and rebuilt the carbs that a former Jag mechanic rebuilt backwards and left leaking. All this in 4 months. Now has over 800 miles and running great. I have retorqued the head twice so far. It is another watch who you get to do your rebuilds. No, I no longer do it professionally.
M
moneypit6
Cheers
Tush
hello tush...
i believe you know the shop,,,maybe you have bought parts from him? In your neighbourhood?
I did manage to drive to the show this past Sunday. I was parked beside Elin, loved his car,,,so glad he is enjoying all his hard work.
Take care,,,
poolboy
Well, you're up to that 500 mile mark....many of us think that's time to retorque the head, which also necessitates resetting the valve lash...After that's done, I think I'd want to do a compression test.
Although the piston rings may not be fully bedded, I think I'd want to know the compression.
It would be nice to have the same shop do it with you standing there observing...but if you'd rather not go back to the shop, at least video the compression test. You may need that.
M
moneypit6
I reset the gap on the rockers the other night
3 were way too big , the rest were so tight I couldn't get my .010 gauge in.
ill retorque the head this coming weekend.
and do a compression test......there is no way I will take my car back to that shop....but a great idea to video tape it,,,and that I shall,,,thank you
poolboy
You're welcome.
The reason I said re-torqueing the head necessitates resetting the valve lash is because you'll have to remove the rocker shaft assembly in order to get a straight shot at 7 of the nuts.
I know there's crowsfoot or the like; but for accuracy, I think you'll have to be directly above the nut with a socket.
Mark_Gibson TR6 Fresh TR-6 Engine Rebuild, Blue Smoke....... Triumph 17
TR4 Fresh Stromberg Rebuild Triumph 4
nitro Fresh Literature Austin Healey 0
LarryK GT6 Fresh purchased GT6 Triumph 11
dougie Fresh Nasty Boy - Well Done Austin Healey 3
M TR6 Tr6 fresh air vent replacements Triumph 1
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
Michael Oritt Fresh air 4" hose installation tricks Austin Healey 23
55modified Anyone install one of these [100S Kilmartin pieces] for fresh air in your footbox? Austin Healey 14
Crankshaft TR2/3/3A Fresh paint prep question Triumph 6
maxwedge5281 63 bj7 fresh air pull Austin Healey 1
C A Fresh Look at Morgan's 100 Year Old Factory Other British Cars 3
B TR6 Fresh air vent seal Triumph 4
L Fresh air and Blower intake hose replacement on BJ8 Austin Healey 12
RickB Fresh Datsun 5 speed and assiciated goodies Spridgets 15
Tim Tucker TR4/4A Dis-assembly of fresh air duct Triumph 8
GBRandy Wedge TR8 [or TR7] Fresh Air Intake Seal - help Triumph 8
T OT - fresh meat Triumph 21
R More Fresh Air in Foot well Austin Healey 5
Superwrench Fresh air hose Austin Healey 11
T OT - Fresh meat for LeMons Triumph 9
P BUGEYE HEATER FRESH AIR VALVE??? Spridgets 14
M TR6 My TR6 Fresh form the Body Shop [video] Triumph 5
S MGB-GT FS: 1969 MGB GT 64k miles, overdrive, a lot fresh. MG 18
J Fresh air system? Spridgets 4
B Fresh paint on a Healey. Austin Healey 5
LBCs_since_1988 Fresh Pair of Rebuilt SUs = Bliss Restoration & Tools 0
T Fresh Paint Jaguar 1
losmorob Heater/fresh air vent on an early '67 Spridgets 1
M Fresh Air Vent Hose Spridgets 13
G Fresh air hose for heater Spridgets 16
B MGB screen material for fresh air vent on mgb? MG 12
Tullamore My box spridgets are breathing fresh air Spridgets 15
Nunyas fresh air vent grill MG 4
AUSMHLY Fresh air intake Austin Healey 23
AUSMHLY Fresh air hose clamp, heater blower ground Austin Healey 5
L Fresh British car owner Triumph 11
A Fresh Air Intake Drain MG 3
B Fresh air duct installation on BN6 Austin Healey 11
JoeC TR6 TR6 Dashboard Fresh Air Vent[s] Triumph 1
Lin Fresh air in the cockpit Austin Healey 5
B Fresh Air Vent door MG 5
Carlbanan56 MGB MGB rear break rebuild MG 6
6 Master Cylinder Rebuild Spridgets 6
wangdango Carb Rebuild Necessity Austin Healey 3
drooartz MGB Front suspension rebuild is next MG 57
KVH General Tech Rebuild Report Triumph 6
