Effect of bad valves on engine performance?
ichthos
What are the effects of bad valves on engine performance? I did a complete rebuild three years ago on my 69 T6 engine, but recently found it has bad compression. I have great oil pressure, but bad readings when I do a compression test. The guy that rebuilt my valves doesn't do very good work (I only found that out after he rebuilt them from friends who had work done there), so that is another reason why I am suspecting the valves. Besides the effects on engine performance, what if any damage can this do to drive with bad valves (it may be summer before I have the money to rebuild the valves)? Any input is greatly appreciated.
Kevin
CJD
A bad (burned) exhaust valve will make the engine run very rough at low speed. The car will buck when trying to creep along at low speed. On the highway it may be completely unnoticeable, depending on how badly the valve is burned.
A bad intake will frequently result in backfiring into the intake. A bad seal on an intake is much less common than a burned exhaust. It is more common for intake valves to stick open...also causing backfiring into the intake.
Of course, for either the compression check will show low numbers. I guess the short answer is that an engine rarely runs well with a bad valve.
TR3driver
Great Pumpkin - R.I.P
Have you tried repeating the compression test with a teaspoon or so of oil added to each cylinder just before testing that cylinder? If the reading comes up sharply, most likely the rings are bad. If it only comes up a bit or not at all, most likely valves or perhaps (if the low readings are adjacent) a blown head gasket.
We're assuming of course that you have checked the valve lash.
Most likely, running with a burned valve won't damage anything but the valve and maybe the seat. You might want to avoid any prolonged full throttle or high rpm operation, though.
I
ichthos
I am seeing some of the symptoms you are talking about, John. I did try the oil, but it does not go up much, Randall. I did not check the valve lash - would that cause bad compression though?
Kevin
martx-5
... I did not check the valve lash - would that cause bad compression though?
Kevin
It would if there is no clearance, causing the valves to not close all the way.
CJD
Old school...you can tell a bad valve with a vacuum gage. The vacuum will pulse irregularly at idle as the bad cylinder comes around on the stroke. A good running engine with good valves will have a steady and consistent pulsing, but no large pulses.
Don Elliott
I you can find a good reliable engine rebuild shop, take the TR in now and ask him to run a "Leak-down Test". He will remove the sparkplugs and screw the leak-down tester into one of the sparkplug holes. Then he will add compressed air to that cylinder with the piston at the bottom for maximum chamber volume. Then the air will leak out that cylinder via the burnt valves (if it is the valves). A good touring engine might leak about 3% to 4%. A racing engine aims for 1 or 2 % leakage. He will then move along to do the other cylinders. If you find one (or more) of your cylinders is - for example - 15 or 20 %, then you need to have the problem addressed.
Harbor Fright sell leak-down testers or some TR owners have made their own.
Don Elliott
Here are two videos how to make your own lesk-down tester and how to use it.
https://www.youtube.com/watch?v=7UcOn8OEt0Y
https://www.youtube.com/watch?v=GvG22YMOzUI
Here is a demo video by a dissatisfied user of a Harbor Freight leak tester. Other videos say the same.
https://www.youtube.com/watch?v=wEYfQbhtNPs
BTW, I stand corrected. The piston should be a the top and the engine should be in gear so that the air pressure doesn't rotate the engine. Readings will be truer if your engine is stll at operating temperature.
poolboy
Hook up the vacuum gauge to your intake manifold , let the engine idle and compare what you see to Scenarios 5 thru 10
https://sbftech.com/index.php?topic=3020.0
F How does overdrive Annulus effect speedometer Austin Healey 10
apbos Coanda Effect, Venting and Airfilters Spridgets 9
tinman58 TR5/TR250 Side effect of a big truck Triumph 3
M TR2/3/3A The "Counting Cars Effect?" Triumph 23
B Aluminium sump and the effect on oil capacity Austin Healey 8
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
K Domino Effect Triumph 6
Lin Effect of elevation on carb tuning Austin Healey 7
S Wedge Ground Effect Package TR7/8 Triumph 8
Steve1970 Effect on throttle plate when pulling choke cable Triumph 2
R TR6 TR6 Cylinder Head Oil Line effect on oil pressure Triumph 10
goloch Alternator Upgrade Effect on Emissions? MG 19
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A Now the bad news. BRAKES Triumph 7
S TR2/3/3A How bad is this? Vertical link Triumph 12
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
roscoe Good news/bad news Austin Healey 11
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
C TR6 Frame Pics, some bad news Triumph 9
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
gbtr6 TR6 Good news, Bad news Triumph 10
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Sixpack TR6 Bad Oil Leak Triumph 24
tinman58 TR2/3/3A Bad thinking? Triumph 25
Geo Hahn TR2/3/3A Bad Day in the Garage Triumph 23
tinman58 General Tech Bad spark plugs Triumph 7
J The Good the Bad and the Ugly Lotus 4
DanLewis How bad does your Bugeye need a boot? Spridgets 6
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
D Spitfire '65 Spitfire MKII w/bad vibes Triumph 4
T is my generator bad? Austin Healey 5
