[ QUOTE ]
Fuses are rated based on the device at the end of the wire, not the power source.
[/ QUOTE ]
Gabe,
With all due respect, I disagree with you. The wire is sized to handle the load of the end device, and the fuse is then sized to protect the wire. A fuse cannot protect the end device. If there is a short on the wire, the voltage/current to the end device will drop, doing no damage to the end device. If the end device faults, then it is already destroyed, and the fuse can't help. The only possible source of excess voltage to any device in the car is a failed alternator regulator, which will generally allow only 18 volts or so, which will usually cause no damage to any device, but the excess current from this most likely won't blow a fuse anyway. 18 volts is only a 22% increase, and most fuses aren't sized that closely.
