General Tech Bad spark plugs
tinman58
I now have about 200 miles on the new TR250. Doing a little carb adjusting, the engine is missing at higher rpm's. So I keep playing with the mikuni carb's. I have never worked with them before. I could not get rid of the miss. I decided to check spark, turn's out there was a bad spark plug. This is the second time this has happened on this car. I replaced all the plugs with new ones and the car runs great. How often do spark plugs go bad? Can the coil fry a plug?
toysrrus
Dan,
What plugs were / are in it?
Russ
PS: I'm running NGK plugs now with about 2k mi. "200mi" is ridiculously low! I initially had Autolight plugs as a temp. & they self-destructed, literally!
bnw
Always use the plugs the factory used to design and dyno test the engine. In your case, that would be Champions. When you've chased that mysterious missfire back to the "right plug, wrong brand" enough times, you will stick to that rule. Autolights, in my experience, are the worst offenders. Also, after years of "professionally " tuning two strokes, NGK plugs have the most accurate heat ranges and are possibly the best plugs out there. Heat range in a high strung two stroke can make the difference between gas fouling and a hole in the top of your piston if you are only one number off. If your 250 engine has been upgraded with a cam, intake, exhaust, higher compression, etc, then find the heat range in NGK that gives you the best plug reading at a full throttle high speed run (key off, neutral, coast to a stop) and stick with that.
tinman58
tinman58
I am using champions. Rn 14y . If there is any more problems I will go to NGK.
poolboy
14....That's a fairly hot plug. Is that the recommended heat range ? I don't think it is...
...Maybe you should try Champion RN12yc or the slightly cooler RN9yc...or the equivalent NGK
If this is the second time a plug in the same loction failed, though, it's probably not the spark plugs fault.
tinman58
tinman58
Rn12yc is. What the specks say. I will get the NGK plugs equivalent to the rn12yc.
sp53
I think the plug wires also have a lot to do with the plug. If you have a Nappa store close by, ask them for a generic set for a V8 or 6 made of metal. They usually have them, but might have to order them from their warehouse.
George_H
Your problem sounds like a problem I had "back in the day". I had a 73 tr6 at the time, Every 2 weeks it would fry a plug. Didn't matter the brand. Turned oud it was a SMALL intake manifold leak. I assume the leak made the plug run super hot until it failed.
J Anemic spark - Bad coil? Triumph 29
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A Now the bad news. BRAKES Triumph 7
S TR2/3/3A How bad is this? Vertical link Triumph 12
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
roscoe Good news/bad news Austin Healey 11
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
C TR6 Frame Pics, some bad news Triumph 9
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
gbtr6 TR6 Good news, Bad news Triumph 10
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Sixpack TR6 Bad Oil Leak Triumph 24
tinman58 TR2/3/3A Bad thinking? Triumph 25
Geo Hahn TR2/3/3A Bad Day in the Garage Triumph 23
J The Good the Bad and the Ugly Lotus 4
DanLewis How bad does your Bugeye need a boot? Spridgets 6
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
D Spitfire '65 Spitfire MKII w/bad vibes Triumph 4
T is my generator bad? Austin Healey 5
T TR2/3/3A Sticker idea; good or bad? Triumph 11
pkmh Distributor rotor gone bad more than once. Austin Healey 5
PAUL161 Moss Motors T Series Parts - Bad Gaskets! MG 5
Boggsy64 MGB Brit are bad engineers MG 17
M My '65 suddenly started running bad today Spridgets 37
HealeyRick Bad Day on the Hill in NZ Austin Healey 7
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
bertl Bad Surgery Triumph 7
J Bad News 1098 Spridgets 14
John_Mc Probably just a bad ground somewhere... Triumph 1
I Effect of bad valves on engine performance? Triumph 9
J How bad do Spridgets leak oil from the crankshaft? Spridgets 18
